Help! Trying to fix Pioneer DVD player
  • Zaxxon
    • Nov 2013
    • 4
    • Japan
    Hi there, I'm new to this forum, so am not sure if this is the right place to post this request. I'm trying to fix a Pioneer DV-S6D DVD player that is not powering on, but has that annoying blinking stand-by light symptom. I checked out the pcbs, and the problem seems to be with the PSU PCB (PSU Assy VWR1316).
    I did some DMM tests as follows:
    - main fuse and microfuses (P211 & P611) are intact and not blown - not sure about R711 (supposed to be a microfuse as well?)
    - Ceramic Cap C151 appears slightly toasted, so I will desolder and test out of circuit (not done yet)
    -Resistor R151 looks slightly toasted, but could be carbon deposits - the color is off, so I can't reliably read the value of the resistor (can anyone tell the value of the resistor from the picture?)
    - I have tested all of the diodes in-circuit and those that appear problematic are as follows: D104 (Zener diode MTZJ2.4B), D311 (leads to +5V rail after passing through IC311), D411 (leads to +3.3V rail after passing through IC411), and D811(leads to EV.+5V)
    I don't have a schematic handy (only the parts list), but have taken pictures as below and circled the above problematic areas.
    My main issue is that I can't identify the specs of the three diodes D311, D411, and D811, since the parts list only shows these as proprietary Pioneer component numbers (D311=VZF1076, D411=VZF1075, D811=VZF1054). Can someone help identify what replacements I can potentially use for these diodes? I have no idea what the current and voltage specs on these diodes should be, so any help would be appreciated!
  • Dvsr
    On M-Audio AV40 active studio speaker's two zener diodes get really hot.
    by Dvsr
    Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
    I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
    After replacing the caps I started testing out the speaker. It seemed...
    09-10-2025, 10:20 AM
  • caspian
    What Zener Diodes on a Linear Power Supply
    by caspian
    Dear members,
    I have a linear variable power supply with unknown brand name that I used for voltage injection.
    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
    In addition, I discovered that its zener diodes are defective.
    I can replace the burned transistors.
    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
    Therefore, I cannot replace the zener diodes.
    I do not want to test the zener diodes in a test circuit to discover their model or value.
    no schematics are available...
    05-26-2025, 12:38 PM
  • Xabi
    Pioneer PD-F1007 CD player not reading
    by Xabi
    Hi guys, I need some help with a CD player. It is a pioneer PD-F1007
    The issue is that it doesn't play any disks. The disk gets loaded, spins up, but it doesn't actually plays. Just keeps spinning until I stop it.
    If I put in the CD the wrong way, it will eject it quite quickly, so the unit at least understands that a CD is in and if it's in the correct orientation, tries to read it, but for some reason it can't.
    I started with cleaning the lens to be sure, but ofc that didn't help. Also the laser is ligthing up at least, so it's not totally...
    06-19-2023, 03:15 PM
  • JimBanville
    Replacing incandescent bulb on Pioneer LD player with led. Need help :)
    by JimBanville
    I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
    Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
    01-24-2023, 07:49 AM
  • Fritter
    Pioneer VSX 531.Sourcing zener diodes
    by Fritter
    Pioneer VSX 531
    I have a zener - ZJ4v3b - to replace on a pioneer AV amp. Closest replacement I can find is NZX4v3b (I think!)
    I can only find them at RS and in quantities of 200.
    Wondered if anyone can guide me to another replacement or a supplier that doesn't require a 200 lot order ?
    Many thanks.
    07-31-2023, 09:23 AM
