sammy LE37C530, bad touch panel or mainboard?
  • senndogg
    • Dec 2011
    • 383
    • Albania
    hello!
    i got a samsung C530 series, 37 inch, with a AUO display. came 2 days before in my service shop completely dead, no led, no life signs.
    this is one is very strange, the owner stated that this was caused immediately after a power surge, but i dont see any faults in the psu. tbh, its a bit strange to me, because when i disconnect the psu <=> mainboard connector the backlight goes on. when inserted back goes off. that means, if i just connect the AC power to the psu i have all the voltages 5V, 13V, 24V there. Maybe this is nothing extraordinary for this kind of TV, its just how it should work. I think i can rule this out.
    The mainboard.
    Normally, I got only the 5V from the psu flowing around. There is also 3.3V in the standby sections. This includes the touch panel section.
    If i bypass the PS_ON trigger, i also got the other 5V and 13V from the PSU, so i have all other voltages in the mainboard, the 2,5V the 1,8V etc. the heatsink of the cpu gets warm too.
    Still no indicator led sign.
    The touch panel buttons.
    This is something which i would be happy to rule out, but i dont know how.
    I have a D400 32" with a broken screen. I managed to hook the D400 touch panel and to my surprise, the led lit! The buttons didnt work actually.
    It would have been simple if i swapped the panels but they cant go vice versa because of different type of connectors.
    what i want to know, is if there is a way to turn on the tv without the touch panel. or another way to tell that the expensive mainboard is ok.
    thanks in advance.
  • tibimakai
    • Jan 2012
    • 3680
    Re: sammy LE37C530, bad touch panel or mainboard?
    With a remote.
    • senndogg
      • Dec 2011
      • 383
      • Albania
      Originally posted by tibimakai
      With a remote.
      tried, with no success with both touch panels. I repeat, the D400 is very different, but i was just hoping that i could rule out the costy motherboard.
      • senndogg
        • Dec 2011
        • 383
        • Albania
        The touch panel is ok. swapped it in a M86BD samsung (which in fact has physical buttons) and worked well.
        Injected 3.3V in the standby rail and still nothing. I guess the new mobo is calling...
        • senndogg
          • Dec 2011
          • 383
          • Albania
          FYI, i did not order the mainboard because of excessive costs.
          But, the TV returned after more than a year around several technicians, and this time i immediately ordered a new mobo from UK. Everything OK now!
          • freakaftr8
            • Oct 2012
            • 3743
            on the back lights lighting up, some Samsung LED TVs are set up in that manner I have a 40 inch Un40es6100 that does the same thing when I disconnect the main board from the power supply. It's just the way the power supplies rigged. So that's probably normal.
            • mmartell
              General Questions on the Relationship Between Mainboard, TCON and Panel
              by mmartell
              My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
              I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
              And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
              01-06-2024, 01:32 PM
            • knoxrebel
              Bad panel or bad mainboard? Visio E601i-A3
              by knoxrebel
              Visio E601i-A3
              Tv powers on and input is able to be selected/used, but the on screen menu closes as soon as it is opened and the there are some periodic "glitches" of the on screen menus in relation to position and size. I have tried all the system resets,but because the menus are not usable, i was unsuccessful. Does this seem like a panel issue? Odd that it only affects the menus and not the main input picture. I have already tried disconnecting front panel buttons assuming one was stuck down causing the input to continually be scanned or similar.
              https://www.youtube.co...
              03-01-2025, 12:14 PM
            • stylishconsultant
              un60j620dafxza - Samsung No Display Problem
              by stylishconsultant
              Hi All,
              Need help.
              I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
              So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
              problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
              might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
              09-04-2024, 03:26 AM
            • trepachka
              Converting HP EliteBook 840 G7 non-touch to touch if possible
              by trepachka
              I am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
              The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
              I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
              04-27-2024, 11:15 PM
            • Prott
              Surface Pro 4/5 - no touch after LCD change
              by Prott
              I have a question that's driving me a bit nuts recently.
              Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
              - I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
              - In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board...
              01-25-2023, 12:42 PM
