LG 32LN575V No picture, sound and backlight working
  • bowman666
    • Oct 2013
    I've go a non working LG 32LN575V, it was described as initially having horizontal lines on it which got worse until there was no picture at all. From doing some reading it sounded like a TCON board fault.
    I also have a 42LN575V wish a smashed screen, looking at the part numbers they are the same for both models, so I tried putting the 42's TCON board in the 32" unit and this didnt fix it. Looking at the TCON board's there are some very slight differences between the two.
    So as a test I put the 32's TCON in the 42" and I do get a picture, albeit the colours aren't quite right. So I'm thinking that the TCON must be ok if I get a picture and that the two boards aren't the same which is why the colours aren't right when the 32's TCON goes into the 42"?
    Does this mean my panel is actually dead? Is it worth a punt at getting new 32" TCON board? I'm reluctant to take a punt as a board off ebay is 40 odd quid.
    Any advice would be greatfully received.
    Many thanks,
    David
    Re: LG 32LN575V No picture, sound and backlight working
    Before declaring the panel dead I'd try swapping the main boards.
    • bowman666
      • Oct 2013
      Hi Tom,
      Sorry I forgot to mention I'd swapped the main boards as well, I've had the two known good boards from the 42" in the 32" and still no picture. Then also both of the boards out of the 32" in the 42" and had a picture, but with not correct colours.
      Many thanks,
      Dave
        That would seem to pretty much indicate it can only be a panel fault. You could get lucky and find just a bad tab bond. These newer LCD panels have crazy bad failure rates!
        • mmartell
          • Oct 2013
          • 3189
          If your T-Con has a TST_PGM landing I've read that if you feed it about 1.5v it will display a test pattern though I have not verified it myself yet.
          • bowman666
            • Oct 2013
            Really sorry for not saying thank you sooner! Thanks very much for the advice. I stuck the TV on eBay for someone else to either have a go at repairing or strip for parts.
            Regards,
            Dave
            • iglitare
              Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
              by iglitare
              i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
              Backlight seems to work, Sound (Setup menu after reset) works.
              If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
              Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
              With my small knowledge i would think at least the cables are good.
              Can this happen because of a bad tcon board?
              Or is it always a bad/shorted...
              09-04-2025, 07:13 AM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • Ierwin
              by Ierwin
              05-13-2025, 03:31 PM
            • jchang
              Samsung UN70NU6900F no picture and no sound
              by jchang
              Hi all
              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
              Symptom:
              No picture no sound.
              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
              No sound at all.
              What I tried:
              1. I tried unplugging the left or right ribbon...
              01-09-2023, 06:28 PM
            • Fly_Among_Stars
              VIZIO E70-E3 Half picture with half TCON
              by Fly_Among_Stars
              I have a VIZIO E70-E3.
              Symptoms: Black screen, no picture, but LED backlights are working.
              I probed the power board and voltages are as listed on the board.
              Main board appears fine, too.
              I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
              There are two separate ribbon cables feeding the LCD.
              If both are connected, the screen is black.
              If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
              04-24-2023, 08:20 PM
