I have this lcd that has no sound (about 2 sec.) And then at random intervals of time (10 ~ 40 sec.) and repeat the fault.He both show the same aerial input and the AV.some suggestions? Complete: as long as the sound goes, I show in the bottom right icon stereo (two symbols dif. s) with a periodicity of about 6-7 sec. i can not enter service mode ("i +, 5, P-, AV, AV). was either sound processor, quartz? ... soft? or another main board?I From Cluj- Napoca, Romania, all the best! :051bye:
lcd tv SONY BRAVIA KDL-32U2000 sound fault
Tags: None
Re: lcd tv SONY BRAVIA KDL-32U2000 sound fault
Check if headphone audio also drops out.
Check if digital audio output, if it has one, drops out.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Thank you very much for your answer, i'll try this.Comment
by alegatorulsony bravia kdl-43w756c, no power, no sound
the charger brick has 19,2-19,3 vcc
changed the inverter board same result.
where should i start?
cheers -
by KYBOSHPrevious owner said TV just went blank one day.
They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
I just downloaded the Sony KD-75X7800F Service Manual and... -
by x_orange90_xFinally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
Has anyone else had this happen to their tv?
10-05-2024, 05:01 AM -
by JUCaESAlHola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television. -
by iglitareHi,
Or is it always a bad/shorted... - Loading...
