I have this lcd that has no sound (about 2 sec.) And then at random intervals of time (10 ~ 40 sec.) and repeat the fault.He both show the same aerial input and the AV.some suggestions? Complete: as long as the sound goes, I show in the bottom right icon stereo (two symbols dif. s) with a periodicity of about 6-7 sec. i can not enter service mode ("i +, 5, P-, AV, AV). was either sound processor, quartz? ... soft? or another main board?I From Cluj- Napoca, Romania, all the best! :051bye:
lcd tv SONY BRAVIA KDL-32U2000 sound fault
Tags: None
Re: lcd tv SONY BRAVIA KDL-32U2000 sound fault
Check if headphone audio also drops out.
Check if digital audio output, if it has one, drops out.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Thank you very much for your answer, i'll try this.Comment
by KYBOSHPrevious owner said TV just went blank one day.
They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
I just downloaded the Sony KD-75X7800F Service Manual and... -
by x_orange90_xFinally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
Has anyone else had this happen to their tv?
10-05-2024, 05:01 AM -
by iglitareHi,
Or is it always a bad/shorted... -
by ryandesignHello! I would like to repair my father's Sony Bravia KDL-40v4100 LCD TV. It was in perfect working order the last time I used it before the pandemic. Then it sat plugged in but unused for a year or more. And now everything still works except that there is no picture on the screen. A relay can be heard to click when the power cable is connected. When the power button is pressed there is a green power LED and then the backlight turns on. If I connect an HDMI cable and play something with audio I can hear it through the speakers. The remote control buttons are recognized. There is just never anything...
by justin35Hello,
i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
from what i read online it looks to be an emmc issue…
i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
i took out the board and say an samsung 16gb emmc
i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
i could try to put one instead of the 16gb one, but will it work?
where do i get the software from?
any help will be much appreciated!...03-06-2024, 12:26 PM - Loading...
