lcd tv SONY BRAVIA KDL-32U2000 sound fault
  • ANDRASONI LUCIAN
    • May 2012
    • 56
    I have this lcd that has no sound (about 2 sec.) And then at random intervals of time (10 ~ 40 sec.) and repeat the fault.He both show the same aerial input and the AV.some suggestions? Complete: as long as the sound goes, I show in the bottom right icon stereo (two symbols dif. s) with a periodicity of about 6-7 sec. i can not enter service mode ("i +, 5, P-, AV, AV). was either sound processor, quartz? ... soft? or another main board?I From Cluj- Napoca, Romania, all the best! :051bye:
    Re: lcd tv SONY BRAVIA KDL-32U2000 sound fault
    Check if headphone audio also drops out.
    Check if digital audio output, if it has one, drops out.
    • ANDRASONI LUCIAN
      • May 2012
      • 56
      Thank you very much for your answer, i'll try this.
      • alegatorul
        sony bravia kdl-43w756c, no power, no sound
        by alegatorul
        the charger brick has 19,2-19,3 vcc
        changed the inverter board same result.
        where should i start?
        cheers
        11-15-2025, 10:00 AM
      • KYBOSH
        Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
        by KYBOSH
        Previous owner said TV just went blank one day.
        They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
        Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
        The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
        There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
        I just downloaded the Sony KD-75X7800F Service Manual and...
        11-19-2024, 10:12 AM
      • x_orange90_x
        Sony Bravia KD-50X690E NO SOUND
        by x_orange90_x
        Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
        Has anyone else had this happen to their tv?
        10-05-2024, 05:01 AM
      • JUCaESAl
        Sony bravia KD-65AF9
        by JUCaESAl
        Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
        Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
        10-20-2025, 04:03 AM
      • iglitare
        Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
        by iglitare
        i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
        Backlight seems to work, Sound (Setup menu after reset) works.
        If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
        Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
        With my small knowledge i would think at least the cables are good.
        Can this happen because of a bad tcon board?
        Or is it always a bad/shorted...
        09-04-2025, 07:13 AM
