Hisense lcd40v57ca 120Hz Ripple
  • kodiac
    • Jul 2010
    • 116
    I have 2 horizontal transparent lines rolling up a Hisense lcd40v57ca TV screen.
    Could this be 120Hz Ripple from bad caps in the power supply?
    Thank You.
    Re: Hisense lcd40v57ca 120Hz Ripple
    I would suspect bad filter caps in the power supply, and in the main board, try heating the caps with hair dryer to see if it gets better.
      Someone else here had a Hisense LCD with a bad main filter cap but they did have different symptoms.
      • PL519
        Tube lover
        • Jul 2013
        • 26
        with 99.9% probability it´s the mains filter cap, since in switching power supplies you only find 60/120Hz on the primary side of the supply. Had the same issue with my satellite receiver, two lines on the screen, sometimes rolling upwards, sometimes downwards. Mains filter cap was totally dried out (not bulged!), no capacity anymore. Replacement should have same or more capacitance, same or higher voltage range, it´s a good idea to take one with higher temp range (105°) for a longer life.
        Greetings,
        Wolf
        • kodiac
          • Jul 2010
          • 116
          Thank You
          • tomketcz
            schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
            by tomketcz
            Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
            10-01-2025, 03:13 AM
          • Coolgoodman
            Faulty Hisense 85Q6NAU TV
            by Coolgoodman
            85” Hisense TV
            Greetings,
            Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
            Dear TV technicians of forum, I hope this message finds you well.
            I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
            I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
            07-24-2025, 03:02 AM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • ShahZaib Ghumman
            Can I Swap Screens Between Two Hisense 75” QLED TVs?
            by ShahZaib Ghumman
            Hey folks,
            I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
            A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
            So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
            03-25-2025, 10:59 PM
          • Antonynl
            What are typical ripple voltages on a laptop motherboard?
            by Antonynl
            I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
            So I have two questions:
            1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
            2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
            Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
            12-09-2022, 06:51 AM
