Re: Z50PJ240 Powers on then back off clicks but no picture
PSU , not sure how core works but I assume it's like a deposit and you get that back when they receive yours?
Good luck.
http://www.encompassparts.com/item/9...s_Power_Supply
yeah you don't wan't power or any residual power either in the caps.
I can't hang on 130 am here. It may not prove anything, have not unearthed anything yet with the other one so feeling like a goose now.
When the boards are cheap enough sometimes safer to get them all but for you maybe psu and if still needed hopefully encompass are good and reliable.
That link, looks like the PSU has an issue, i'm seeing none new and refurbs plus they want the bad one . $60 with your old one , all the other boars ysus,zsus and both buffers for another $100 if i've got it right.
here's the list, I put the same in the other post.
http://www.encompassparts.com/item/8...t_Pcb_Assembly
http://www.encompassparts.com/item/8...vtp_Board_Assy
http://www.encompassparts.com/item/8...1/Ydrvbt_Board
http://www.encompassparts.com/item/8...40301/Zsus_Pcb
Just over a $100 for all if I'm seeing right>Leave a comment:
I can still test the resistance but need a little more directions on how to do it. Can I do it with no power like checking a resistor?Leave a comment:
throw some part numbers in here in case they're cheaper. Just found a ysus for $30 equivalent replacement not sure about their shipping.
http://www.encompassparts.com/item/8...t_Pcb_AssemblyLeave a comment:
Ok well that probably makes the PSU suspect from the start, you've probably seen the LG 50PJ350 post today and his powers up solid with no sustains hooked.
as soon as he has the Ysus it quits, click on then off. He's checked the PSU and done the bench test with bulbs and it's staying good.
Sorry if I gave you the run around, I thought at some stage in the repair you had the PSU up.
can't belive what they want for each board though, ysus are $90 upLeave a comment:
I see what your saying but I did unhook those from the very start and never got any power. So if they damaged the power board it would of been before I did the resister test.
Funny thing is when its all hooked up and I get lucky on a click and it will power on for a minute or 2 and everything looks normal before it will click off. Could take 50 tries to do that again. That's one reason I got lucky doing the resistor test once to check the voltage. Don't know why I never saw a test pattern.Leave a comment:
What if it was working but the sustains were bad and damaged it because you forced the PSU on with that test with the resistors when the PSU test probably should have been done on it's own ?
That's something we won't know now.
It's all just theory. If the PSU is now totally dead, you'll need a PSU and the rest if it's bad as well you'll just have to work out if it comes to that.
Just looking at worst case what if you need PSU, YSUS, Zsus, buffer?
Sorry i wish i knew this model better but I simply don't and all i know is what i'd be looking at just in case.
The PSU may fix it, how can we prove the rest unless there's an obvious short or something I don't know.
I don't know what else to offer you, sorryLeave a comment:
Wouldn't it stay powered up by unhooking those if those were bad?Leave a comment:
Would I have to plug it up and be getting voltage to it to check that?Leave a comment:
well, I thought I read at some point the power stayed up and you had voltages to check?
Did this happen and did you take the opportunity to check if all voltages were present?
If the voltages were up, the control board was on and normal, jumpered for the test patterns but no image, I have to wonder.
I'd like to see if you can check out the sustains and buffers for any shorts. Check the resistance at the power connections on the Ysus and zsus. At least if you can post those up i can at grab mine and see if there is any wild differences.
It may be completely a waste of time and not the fault. I just think checking these out is not a bad idea because i can give you a good indication from my end of these boards I have which I know the TV powered up fully with both sustains firing.Leave a comment:
So is still possible that it could be in the sustain boards or buffer boards?Leave a comment:
Same as mine, I can't remember but did it ever power up and stay on with both sustains isolated?Leave a comment:
The part number comes up on SJ but just one version, yours with the 3 resistors. where are you getting the replacement from?
Mine has three boxes for model ID, LGIT PSPI-L912A AND IS RATED 100-240V AC INPUT, 50/60HZ, 5AMP 360W PDP MAX,17V 1A, 5.1V 3A, STDBY5V 1A, VS 197-207 1.6A, VA 60V 2A, 2010.6.14 REV 1.4Leave a comment:
$83 to $140 most places are out of stock though. SJ is out of stock. Found one on ebay that has 2 resistors. it says it fits my model # but wanted to check with you guys to make sure.Leave a comment:
SJ site just crashed. what's a PSU going to cost?Leave a comment:
I'm going to say yes. Your PSU part number and mine are the same. Mine has 2 resistors. PCB # mine is rev 12 (/12) yours is #11(/11) but being the same PSU part # it's doing the same job.
I'll jump on SJ and see if they sub but it would be ok I expect.Leave a comment:
I think I'm just going to replace the board. Just need to confirm my answer in my no. 2 question. My board has 3 white resisters, can I replace it with one that has 2?Leave a comment:
by PNI E.hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
by koby058Hi people!!
The owner said it showed bad picture once in a while (attached)
I see that there is back light but no picture.
I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
Also attached schematic and BDV
LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590... -
by csmithI replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
issue. Set will power up with remote but not power off.... -
by sergio_avHi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...1 Photo -
by KYBOSHSaved this beast from the landfill this weekend.
Manfactured July 2013 in Mexico.
I love working on plasma TVs.
Its been a while but I was lucky enough to find 2 this week.
The TV powers on and stays on but no picture. Havent checked for sound yet.
No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
Will start troubleshooting tonight.
... - Loading...
