Samsung LN-S4041D vertical RBG lines- ongoing repair
  • jjvaughn83
    • Oct 2013
    • 6
    So, I have done over 6 hours of repair and research trying to fix the screen of my older 40" Samsung LN-S4041D LCD. I am getting the familiar black screen with no audio but I have thin, randomly spaced, vertical red blue and green lines. I still have good audio but obviously none of the menus will come up.
    I inspected the power supply board and found no obvious failed capacitors but I still replaced the usual culprits anyways. I did use cheap Radio Shack caps (I already had them in the drawer) with the intention of replacing them with better caps if the repair worked. There was no difference in the screen after the cap replacement.
    I checked all voltages coming off the board with the unit on and plugged in. Every output voltage specified on the circuit board was dead on correct.
    I inspected the areas that others have pointed out with bad soldering. Worked it over pretty good with a magnifying glass and still no luck finding any obvious failures.
    I then removed the"tcon" board near the top of the screen to give it a good inspection. I checked the small SMD fuse near the input ribbon connector and it was showing a good circuit and allowing 5 volts to pass through to the rest of the circuitry. Just for fun, I disconnected the TCon board from the video board and fired up the Tv. It booted up just like normal except the lines were gone from the screen. This leads me to believe it could be the TCon board that is causing the ultimate issue.
    I am looking for more information on these Tcon boards. Info about repairing the board itself and/or replacement information would be very welcome!
    Re: Samsung LN-S4041D vertical RBG lines- ongoing repair
    I've done this one (UK variant of it.) One of the three voltage regulators on the t-con is failed if you get vertical lines. They all output 2.5V IIRC, but one had failed on mine outputting about 1.3V.
    • jjvaughn83
      • Oct 2013
      • 6
      Can you please point me in the right direction? I'm not sure where the voltage regulators are at on this board.
        Each highlighted device is a regulator.
        To test: TV powered on with fault. Multimeter set to 20 volt DC or autoranging volts DC. Black probe on chassis, red probe on each pin of the device. Note down voltages on each pin. You can skip the fat "tab" pin as that is electrically the same as the middle pin. Report results back, with the "refdes" e.g. U35 printed on the board. and part number e.g. "UMC1117-33" which is printed on the device. Pin order doesn't matter, number them mentally, but be consistent between regulators.
        For example:
        regulator U11 part "UMC1117-ADJ"
        3.29 0.58 2.53
        • jjvaughn83
          • Oct 2013
          • 6
          Checked all 3 and the voltage readings are consistent.
            That's a surprise.. not the same issue. Huh.
            Can we get a picture of the problem just so I can see if it looks the same as what mine did?
            Mine had exact same T-con/power board and UK main board.
            • jjvaughn83
              • Oct 2013
              • 6
              When the TV first boots up, the lines show up but dimly. After about 10 seconds, the color in the lines become more pronounced. Thanks again for your assistance so far!
                That is exactly the same fault I had. If you cannot find a bad voltage regulator I suggest you just replace the T-con board.
                • jjvaughn83
                  • Oct 2013
                  • 6
                  Where would be the best place to source the board?
                  • Falki
                    Colorful LCD Vertical Lines on Samsung ue55es8090
                    by Falki
                    Hello there, ive recently found an older 55inch Samsung SmartTV.
                    A similar issue has been posted as well but also with no actual response ...
                    08-12-2025, 04:19 AM
                  • Stanley1843
                    by Stanley1843
                    06-29-2024, 11:54 AM
                  • pni
                    LG 49uf695v vertical coloured lines
                    by pni
                    Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                    11-14-2025, 03:15 AM
                  • x_orange90_x
                    Samsung UN46C8000XFXZA vertical bars/horizontal lines
                    by x_orange90_x
                    I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                    The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                    09-04-2023, 12:09 PM
                  • polaro
                    Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                    by polaro
                    Greetings,
                    I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                    08-27-2022, 08:46 AM
