TC-P42C2 - Need advice
  • fyca
    • Sep 2013
    • 18
    Re: TC-P42C2 - Need advice
    Looks like I'll be ordering the SS then. I'll let you know the outcome. It'll probably take a week or so.
    Do you think the bad SS could be causing my 6 blink SOS? from the ERC?
    • fyca
      • Sep 2013
      • 18
      Originally posted by tw2005
      unlikely you have a P-board issue,SS board failure is a common one for this model.
      Alright that's all the re-assurance I need to get ordering.
      • tw2005
        • Oct 2011
        • 6458
        I just hope you don't end up like the last guy I tried helping when out of the blue the a-board quit on us .
        • fyca
          • Sep 2013
          • 18
          Lets hope that doesn't happen. Atleast if that's the case I can return the SN and SS back to ShopJimmy and sell the PDP.
          • cloo
            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
            by cloo
            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
            After doing a factory reset this problem was gone and the picture was back to...
            01-06-2025, 06:02 AM
          • EazyBone
            Un50cu7000 2 blink oddity *partially solved
            by EazyBone
            I write this to maybe help another with this TV.
            So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
            The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
            03-18-2024, 10:24 PM
          • Vebririon
            panasonic TX-P50V10E 6 blink led problem
            by Vebririon
            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
            05-17-2025, 10:16 AM
          • pixelcap
            Pioneer Kuro Pro 111FD 8 red blink error
            by pixelcap
            Pioneer Kuro Pro 111FD 8 blink red LED.
            I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
            So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
            based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
            10-06-2024, 11:26 PM
          • nervx
            Panasonic TH-42PZ800 8-blink error mystery
            by nervx
            Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
            Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
            04-08-2022, 05:19 AM
