I will start at the beginning. I acquired this TV from a friend who said it no longer worked. Being technologically inclined I plugged it in to observe what its problem was. It turned on and displayed but it was not displaying a clear picture, rather just distortion, but when I pressed the menu button I could see parts of it on the screen. So I figured it would be an easy fix, after looking through all the forums here on BadCaps and AVS I did a couple of the tests and figured it was probably the P board. After a couple of weeks my brother came over and wanted to see what was wrong with it and out of no where it was working with no visual problems, then after about 15 mins the video started to fade out to what it was doing originally, then it finally turned off to 7 Blink SOS. After looking through the forums again I found a procedure that said to disconnect SN20 and SN2 and if the blinks changed to 6 it indicated that the SN was bad so I ordered a new SN board - Original board had number TNPA5066 but on a little white tag said 5066AD - the new board I ordered was TNPA5066AC which ShopJimmy listed as a substitute part. Now the tv turns on again, but after about 5 seconds shuts off to 6 Blink SOS. Then I found the 2010 FHD Manual for the TC-P42S2, as I could not find one for the C2. I did one of the tests which said to disconnect SN20 and C10 and if the blinks changed to 8 that the SC was shot, being the C2 model the SC is built into the SN. Now I'm back to the SN being bad. I have tested the voltages that I could, VSUS 188.9V steady TPVAD -188.9, my 15V line on the VSUS connector measured 15.5V and all 15V lines measure 15.5V and the 5V lines measure 4.97V. I also tested if I disconnect SN2,SN20,SS11 and the result is 7 Blink SOS. I am now at kind of a stand still as I have looked everywhere for more info and can not find much in terms of service procedures. Does anybody have any Ideas or any test procedures I should perform? I don't think the panel is bad since it had at one time after being broken it worked like it should. Also another note, I did notice when it worked for its brief moment that it seemed to retain images after being reset, but when active it did not display the images.
TC-P42C2 - Need advice
Re: TC-P42C2 - Need advice
This post p42x20 probably won't help you much, I found it confusing to read again and I wrote it!
Anyway, yes I had a lot of fun trying to understand the SOS blinks and trying to apply the 2009 model training to it and I suspect some of those isolation steps could be wrong for this one.
I got mine going in the end but the image is wrong, maldisharge, simply weird.
I had shorted Vsus(SOS4) on the SS board(common fault), corrupted EEPROM on the A-board(SOS1), Then I found corrosion on the flex cables from the A-board that damaged some octal buffer ICs on the A-board shorting 5V (SOS10), then somehow shorted out and IGBT on the SN ERC cct from the SS, still had issues, had both SOS6 & 8, followed that isolation procedure and it suggested SN board but I could not find anything shorted on it.
Took a punt and figured C boards could also cause SOS8, found a bad IC on the C2 board ( I think) replaced that and finally had a picture but not 100% correct.
No longer shutsdown but it's a basket case, however if you want to compare what blinks out depending what is disconnected, list them and I'm happy to try them out and post the results.
every board in mine is the same as yours except the A-board.
I know if I disconnect the interconnecting ribbon between C1 & C2 boards (C10)it goes SOS8.
SN20 + C10 = same SOS8
SN20 on it's own SOS6, poorly seated or corrosion on the ribbon can also cause SOS6, I had corrosion and used parts from a 42C2 to replace it.
SN2,SN20,SS11 I get SOS6 not 7
I can't see how you could get SOS7 with SN20 disconnected as the A-board needs that one connected to receive the SOS7 trigger from the SN board. By default , SN20 disconnected should produce SOS6, A-SN FPC DETLast edited by tw2005; 10-19-2013, 09:32 PM. -
This post p42x20
I can't see how you could get SOS7 with SN20 disconnected as the A-board needs that one connected to receive the SOS7 trigger from the SN board. By default , SN20 disconnected should produce SOS6, A-SN FPC DETComment
So my bro came by and helped me test some points.
TPSN1 - 60V not stable, switched between + and -
TP97 - ~ -120V switches between + and - drops to -104 after screen on
TP98 - ~-163V after screen on drops to about -80V
TPVSCN - -43V
TPSS1 - 121V after screen on drops to 105V
TPVe - 123.7V
TPVAD - -188.9V right before the relay clicks off it dips to around -178V then back up to -188.9V then the relay clicks off.Comment
TPVSCN - -43V
TPVe - 123.7V
As I was reading your thread on the X20 I saw that you test the ERC Mid, I do not know the procedure for testing that, although I did try to measure it with black lead on white wire at SN3 and red lead on the brown wire, both wires test at ~120v for both brown wires.
EDIT: After testing again with black lead on chassis ground, this happens on both brown wires, the voltage starts at 15V then goes to 119V then 121.2V then down to 105V.Comment
So now on to something new, I just removed my A-board and my SS to visually inspect both. Upon inspection nothing looks visually bad, but now I have a 10 Blink SOS. I took everything back apart and put it together again and I still have 10 Blink SOS. I don't know what happened. Also with SN2,SN20,SS11 disconnected and I test VSUS now it goes to 188.9V but dips 1/2 second before relay clicks off and I also get the 6 Blink SOS. Does this mean my P board is dead? Same thing with the 15V line dips before the relay clicks off.Last edited by fyca; 10-20-2013, 02:34 PM.Comment
Sounds like the SS may have failed shorted, check vsus at SS11 to gnd on the board for short obviously isolated and check there's no residual voltage before you do.
Maybe also check P15V @ SS11 and SS23 P+5v for short to gnd.
SS11 disconnected should produce SOS6, mine does.Last edited by tw2005; 10-21-2013, 03:13 AM.Comment
Would it be worth changing the IGBT's or just get a new SS? I could pick up a used SS on ebay for $30. In this case could it be more than 4 IGBT's, like I've read if something went wrong on a board it was probably caused by something else, personally would you change the IGBT's or just get a new board?
Edit: It looks like it would cost me about $20 for four IGBT's from Mouser. Used SS it is I guess. Hopefully it's not my P-board that shorted it. Would the IGBT's possibly also be my 6 SOS?Last edited by fyca; 10-21-2013, 10:40 PM.Comment
Just as reference these look like they would be exactly the IGBT's I would need.
http://www.mouser.com/ds/2/200/irg7ia19upbf-89228.pdfComment
I'd get the board, just takes that doubt out, for me adding postage doubles the cost so I chose component.Comment
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
by EazyBoneI write this to maybe help another with this TV.
So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
...03-18-2024, 10:24 PM -
by VebririonHi everyone,
I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report... -
by pixelcapPioneer Kuro Pro 111FD 8 blink red LED.
I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...1 Photo -
by nervxYears ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a... - Loading...
