technika 32"
  • futurespec
    • Oct 2013
    • 24
    • United Kingdom
    technika 32"
    unbranded 32" lcd tv L2M08 MAIN AV BOARD
    I HAVE A PROBLEM WITH SOUND
    THE SOUND WORKS WHEN TURNED ON AND AFTER 20MINS THE SOUND GOES
    NEED DIAGRAM OF THE BOARD AND ANY INFO SO I CAN REPAIR PLEASE
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: technika 32"
    It sounds like you may have an ic failing. You can try to freeze the chip and see if your sound returns. You might also check the voltage regulators on the main to verify they are outputting the correct voltages, a low voltage could potentially cause the sound to drop out. Several voltage test points can be found across the top of the board in your picture.
    ET shows two manuals for Technika 32" tvs HERE
    Liberating magic smoke one part at a time
    • futurespec
      • Oct 2013
      • 24
      • United Kingdom
      Re: technika 32"
      i cant use the file as i dont know what program to use to open it
      where is the ic chip located on the board and you indicate to freeze the chip how would you do that
      • notallbad
        • Oct 2012
        • 1190
        Re: technika 32"
        The file is just a .PDF document
        Adobe reader
        Freeze it with ice cubes or just put it in the freezer for an hour, seriously you need freeze spray.
        • notallbad
          • Oct 2012
          • 1190
          Re: technika 32"
          Why do you have bent, possibly shorting, pins on the CI Card port?
          Ha, is this an actual picture of your board?
          • Caleb
            Smokin IC's
            • Feb 2013
            • 645
            Re: technika 32"
            You can use canned air held upside down for freeze spray, Notallbad was joking about the ice cubes dont use them. The voltage regulators look like the component above K. Maint. Pyne. sticker above the T in Maint. Audio ic will likely be one of the qfp ics but you will have to find the appropriate schematic or trace back the audio output.
            • futurespec
              • Oct 2013
              • 24
              • United Kingdom
              Re: technika 32"
              ive managed to use a small fan and soldered the wires to the av board and its been on for 2hours with sound fully working
                Re: technika 32"
                Which component did you direct air at?
                • futurespec
                  • Oct 2013
                  • 24
                  • United Kingdom
                  Re: technika 32"
                  where the tv card goes i placed a fan there.
                  about 4 ic chips or more in that area is cooled with the fan
                    Re: technika 32"
                    You really need to narrow it down.
                    You can buy canned air which also acts as freeze spray from Poundland in the UK.
                    • futurespec
                      • Oct 2013
                      • 24
                      • United Kingdom
                      Re: technika 32"
                      need to have a diagram or schematics to help me
                      • futurespec
                        • Oct 2013
                        • 24
                        • United Kingdom
                        Re: technika 32"
                        is there anywhere i can get hold of technika or unbranded l2m08(03) av board
                          Re: technika 32"
                          Good luck with that, I doubt one was ever released, these are intended as throw away TVs.
                          • futurespec
                            • Oct 2013
                            • 24
                            • United Kingdom
                            Re: technika 32"
                            ive got hold of a complete set of boards speekers and cables for the technika 32"
                            www.bixreclamation.co.uk
                            technika lcd32-600 32" lcd tv dealer service repair kit
                            all fully working now
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • LEECH666
                              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                              by LEECH666
                              Good day ladies and gentleman!
                              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                              01-19-2024, 05:46 PM
                            • Christos Tsiligiannis
                              Marian Trace Alpha sound card repair help
                              by Christos Tsiligiannis
                              Hello to the forum.
                              My name is Christos, I am new to the forum here and i am posting from Greece.
                              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                              So i tried asking for a schematic from the company and they would not give me one. Instead they...
                              11-18-2024, 05:26 AM
                              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                              This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-12-2024, 02:30 PM
                              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
