akira pk8401 84" multi pdp
  • newtothis
    • Mar 2013
    • 1556
    • england
    Have one of these sets going cheaply near me... Set powers up ok but won't display any input... So board replacement...
    Problem... I have no idea where to source these parts... Any ideas?
  • notallbad
    • Oct 2012
    • 1190
    Re: akira pk8401 84" multi pdp
    Not any input at all? scart, component, usb, vga d-sub, hdmi
    Does it show the TV Menu options etc...?
    • newtothis
      • Mar 2013
      • 1556
      • england
      As far as I know it shows nothing at all via any input... Not sure about menu... Will ask
      • notallbad
        • Oct 2012
        • 1190
        OK so this is a plasma, 84", WOW!!!
        Could be a multitude of problems though, display panel, X or Y sus, main board, just to name a few.
        Have you tried to see if any spare boards are available anywhere? The only option could be to repair at component level as I shouldn't think there would be many parts readily available.
        How competent are you at diagnosing/repairing yourself is really the biggest question (with/without assistance)?
        • notallbad
          • Oct 2012
          • 1190
          I'm guessing that this 84" is made up by 4 x 42" display panels giving 84" overall.
          Its a multi panel PDP (plasma).
          • newtothis
            • Mar 2013
            • 1556
            • england
            Yes it's a 4 panel seamless display... It does show menu's according to the seller.
            I have repaired at few boards at component level with a little help from here.
            • notallbad
              • Oct 2012
              • 1190
              Well at least thats a good sign if something shows on all 4 screens, it does show on all 4 screens???
              I would imagine that each of the 4 displays are standard panels so you could potentially get a return on the panels alone if all goes pear shaped.
              There must be a central board that splits the display signals across the 4 displays and I would say this is the most likely board at fault.
              • notallbad
                • Oct 2012
                • 1190
                Looks like they only buy WORKING tv's which is a good sign! And they have bought a lot!!! There name gives it away a little too!
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Yes it shows on all four displays... So must be the input board at fault... It's on collection only via eBay very close to me... So hopefully it won't Attract to many bids and get it cheaply... It also comes with it's own flight case which must be worth a bit too. I was thinking the same and if it did go pear shaped I'm sure if gained cheaply enough I may be able to make a few quid breaking it for parts.
                  If the input board has died what are the chances of repairing these boards at component level?
                  • notallbad
                    • Oct 2012
                    • 1190
                    Its possible its the Digital Video Processing Chip fried, hence why no inputs are working but hey could simply be a volt reg but not sure that these would cause no display from all inputs. Analog and digital signals are usually processed separately so if no inputs are working it must be common to both.
                    • notallbad
                      • Oct 2012
                      • 1190
                      You are going to have to buy it now as I am curious to the inners of this.
                        It will probably be four standard 42 inch 720p (or 480p) panels, with a control board to divide the signal into four monitors. Expect the panels to have burn in if they have been used to display static content.
                        • newtothis
                          • Mar 2013
                          • 1556
                          • england
                          Even if they have burn if I can get it cheap enough I don't mind... I'm going to go inspect it Monday so will update then
                          • newtothis
                            • Mar 2013
                            • 1556
                            • england
                            Just been informed that actually only 3 screens light up and there is no menu showing!
                              Possibly the menu shows up in missing monitor. You'd likely be looking at repairing one of the 42" modules.
                              • newtothis
                                • Mar 2013
                                • 1556
                                • england
                                Was thinking that... Any idea if that single panel would stop inputs from showing?
                                  Maybe if one panel is designated the "master" it will cause the others to fail working.
                                  • newtothis
                                    • Mar 2013
                                    • 1556
                                    • england
                                    Now is the time to contact the manufacturer and see if I can obtain a service manual for this set
                                    • notallbad
                                      • Oct 2012
                                      • 1190
                                      I see bidding ended at 87, but was it you?
                                      Seems a bit sus, winning bidder with zero feedback, erm.
                                      • newtothis
                                        • Mar 2013
                                        • 1556
                                        • england
                                        No I let it go
                                        • malogro
                                          Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                                          by malogro
                                          Hello all,
                                          I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                                          Intro:
                                          This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                                          Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                                          04-14-2023, 04:44 PM
                                        • Kezi Gamer
                                          Marshall stanmore multi room
                                          by Kezi Gamer
                                          Hi, recently i have encountered problem with my Marshall stanmore multi room speaker, speaker itself works fine using app from my phone but knobs on actual speaker doesn't work. First thing that came up to me is that maybe something is shorted on the top board and after disassembling the speaker and checking with multimeter I could not find anything wrong, also on the panel multi, and next song button are working and nothing else. Any help is very appreciated​...
                                          03-24-2025, 08:37 AM
                                        • jose6326
                                          Samsung s32d850t powers off
                                          by jose6326
                                          Powers on as normal shows an image then powers off after 10 seconds
                                          I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                                          No blown caps
                                          I searched for this model but nothing comes up...
                                          11-29-2024, 11:21 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO SVF15N1D4E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF15N1D4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF15N1D4E boardview and SVF15N1D4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
