LG 50PQ30 Heatsinks
    Re: LG 50PQ30 Heatsinks
    If control board is shutting down it won't send signal to either so no heat will be produced, also, if the panel is not lit, no heat either as no substantial current is being pumped into it.
    • pposey
      • Oct 2012
      • 60
      So are you saying that the Z-sus is shutting down the control board or is it possible the control board is faulty as well?
        I suspect the control board is detecting a fault in either Y- or Z-sustain and shutting the sustain process down.
        • pposey
          • Oct 2012
          • 60
          ok im about to give up on this thing. I have replaced the y and z sustain and also the control board. The control board now has a light on it blinking but still no picture. Also where before i was getting actually sound out of it, it is no a static sound and i tried changing the input to no avail. Would anybody have a idea on what it could be? This is really frustrating but i do not like anything defeating me lol
          • pposey
            • Oct 2012
            • 60
            Any ideas anybody? I really don't wanna dump this TV.
            • pposey
              • Oct 2012
              • 60
              Found the problem! Bottom y buffer board! Thanks for your help!
              • pposey
                • Oct 2012
                • 60
                I have one quick question though. When i removed the bad board the upper board would show a picture but it has vertical red and black lines. Is that normal when the other one is removed?
                • legg
                  LG 42PC3 buffer output doesn't follow YSUS
                  by legg
                  LG42PC3D -UD originally with green lamp but no display or audio.
                  Owner says was working, then went 'pop'.
                  All 5V caps bulging. replaced.
                  All PSU output voltages within spec but -Vy is low on YSUS.
                  One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                  eventually shorts DG. Replaced all 3 - -Vy now OK.
                  Y scan buffer test point does not follow YSUS output below -50V
                  Note: This unit seems to expect YSUS output to park at -Vy in between
                  drive signal pattern periods. A replacement drive signal board confirms this....
                  11-18-2021, 11:49 AM
                • Truncatedhose
                  Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                  by Truncatedhose
                  Greetings all!
                  Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                  Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                  07-04-2018, 10:59 AM
                • zwarder
                  eax61319402 50PJ350 YSUS
                  by zwarder
                  Hi
                  Had shorted YSUS
                  Q24 RPJ63F3
                  C726 cap
                  Q11 K3667
                  R528 & R529 2.2 ohm
                  replaced all of these but still trips psu VS & VA are a bit low when ysus disconnected. IC301 does look a bit burnt however
                  ZSUS is also good as far as I can tell
                  Anyone could help me out on this one
                  10-23-2023, 08:11 AM
                • maces
                  LG 60PH6608 YSUS repair
                  by maces
                  Hello all,
                  I have a problem with my LG 60PH6608. The TV is only clicking and doesn't get started.
                  I checked the power supply and measured that the 200V is shorted at the YSUS board.
                  All IGBTs, the MOSFET K8A60DA and the diode D603 are shorten.
                  So I replaced the parts. I checked the further parts for shorts and I was pretty sure that there is no further problem on the board.
                  So I plugged it in. Directly, resistor R251 (2,2 Ohm) blowed out with a little spark. Immediately I disconnected the TV from supply.
                  I checked the replaced parts (IGBTs, MOSFET...
                  12-11-2022, 02:21 AM
                • Uranium-235
                  Money for scrap computers and copper heatsinks
                  by Uranium-235
                  Has anyone ever gone down this road? I have a number of copper (and copper plated :/ ) and aluminum heatsinks. As well as full computers. Ever heard of any companies that will buy them off me (for not that much probably). I've been sending them to e-recycling
                  I kept a beige taaaaall antec case, going to try TC's yellowing remover and try to create an old system. Probably multiboot with DOS and 98 and 2k to cover all my bases
                  Maybe even use a certain Voodoo5 card in it
                  10-09-2022, 01:44 AM
