LG 50PQ30 Heatsinks
  • pposey
    • Oct 2012
    • 60
    LG 50PQ30 Heatsinks
    Hi. On the YSUS board, can you replace the output transitors on the heatsink if they are shorted? And kind of a dumb question (still trying to learn this stuff) i tested them by the troubleshooting manual of this tv and if it says for instance there is suppose to be .38V from point a to b but it shows OL on my meter, does that mean it is screwed up? Thanks
  • capkid
    • Oct 2010
    • 1339
    Re: LG 50PQ30 Heatsinks
    You should be able to change out a transistor on the heat sink. What is the part number of the component you're trying to test?
    LG Plasma Mal-Discharge Correction Service
    • pposey
      • Oct 2012
      • 60
      It is transistor Q34 on the ysus board.
      • pposey
        • Oct 2012
        • 60
        Should i use a npn or a pnp transistor to replace these if there bad? Thanks again
          Neither.
          You should replace them with IGBT or MOSFET, exact type being indicated by the part #.
          • capkid
            • Oct 2010
            • 1339
            The part number should be inscribed on the front of the transistor. Q34 is probably the location of the transistor on the Y-Sustain. Are you sure it's bad and that you didn't just incorrectly measure it? Also, if you tested it in circuit, your readings may not be accurate.
            • pposey
              • Oct 2012
              • 60
              Oh ok. The part number is 30f124. I tested it a few times and according to the diagram it should have a 2.02v reading but im getting OL on my meter. I measured these readings with the board out of the tv.
              • pposey
                • Oct 2012
                • 60
                Originally posted by tom66
                Neither.
                Ok, thanks tom! Also i have one more question. I left the tv on for around 30 minutes to see if the heatsinks would warm up and none of them on either the z or y sus did. Does that mean both boards are bad?
                  Not necessarily, if the panel is not lit up, the boards will not heat up as they are not pumping current into the panel, this can be caused by a bad control board, bad main board, shorted Y- or Z-sus (one or both)...
                  • pposey
                    • Oct 2012
                    • 60
                    Ok thanks there Tom, i was starting to worry alittle bit lol.
                    Is it normal for so many of these Mosfets to go bad on a heatsink at once? I found 7 just on the YSUS. It is the part number 30f124. It says in the manual that im suppose to get 2.02v when i connect the red lead to the first prong and the black lead on the middle prong but i get OL.
                      Which manual are you referring to?
                      There are often FETs/IGBTs in parallel, so a whole bank can show shorted, but usually only one actually is failed.
                      • pposey
                        • Oct 2012
                        • 60
                        It is the 50PQ30 training manual. Is there a way to tell which one has failed?
                          Remove them and test them out of circuit. Can be frustrating.
                          • pposey
                            • Oct 2012
                            • 60
                            Alright buddy will do. Seems like alot of work but i am willing to do it. This is my frist plasma im trying to fix. Seems just a tad bit more than an lcd to deal with but i like this kind of thing. I have fixed 3 Lcd tvs so im trying to break the plasma barrier lol. Thanks again for your help. I will be on here as soon as i can test them all and give you an update.
                              Plasma TV pictures look so much better than LCD -- it's worth it!
                              • pposey
                                • Oct 2012
                                • 60
                                Just a quick update. I have taken 3 out but with no luck. I think i may be messing them up when removing them. It has OL on all three from the first prong to the second.(Sorry i do not know the name of these prongs) I ordered me and solder sucker to help me get these suckers out. Seems like i have to get it really hot for the solder to even start melting.
                                  Decent solder wick such as Chemtronics has never failed me.
                                  • pposey
                                    • Oct 2012
                                    • 60
                                    Thanks for the tip! BTW i found a small fuse on the control board which is blown. How do i go about finding one of those bad boys? its a m5v fuse i think.
                                    • pposey
                                      • Oct 2012
                                      • 60
                                      http://imgur.com/VWbBlmX
                                      Is this even fixable? Or even worth it?
                                      It is straight underneath a heatsink.
                                        If that device burned, that will only usually occur due to a FET on the nearby heatsink going shorted.
                                        • PlasMatt
                                          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                          by PlasMatt
                                          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                          09-20-2025, 06:50 PM
                                        • legg
                                          LG 42PC3 buffer output doesn't follow YSUS
                                          by legg
                                          LG42PC3D -UD originally with green lamp but no display or audio.
                                          Owner says was working, then went 'pop'.
                                          All 5V caps bulging. replaced.
                                          All PSU output voltages within spec but -Vy is low on YSUS.
                                          One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                          eventually shorts DG. Replaced all 3 - -Vy now OK.
                                          Y scan buffer test point does not follow YSUS output below -50V
                                          Note: This unit seems to expect YSUS output to park at -Vy in between
                                          drive signal pattern periods. A replacement drive signal board confirms this....
                                          11-18-2021, 11:49 AM
                                        • Truncatedhose
                                          Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                                          by Truncatedhose
                                          Greetings all!
                                          Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                                          Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                                          07-04-2018, 10:59 AM
                                        • zwarder
                                          eax61319402 50PJ350 YSUS
                                          by zwarder
                                          Hi
                                          Had shorted YSUS
                                          Q24 RPJ63F3
                                          C726 cap
                                          Q11 K3667
                                          R528 & R529 2.2 ohm
                                          replaced all of these but still trips psu VS & VA are a bit low when ysus disconnected. IC301 does look a bit burnt however
                                          ZSUS is also good as far as I can tell
                                          Anyone could help me out on this one
                                          10-23-2023, 08:11 AM
                                        • maces
                                          LG 60PH6608 YSUS repair
                                          by maces
                                          Hello all,
                                          I have a problem with my LG 60PH6608. The TV is only clicking and doesn't get started.
                                          I checked the power supply and measured that the 200V is shorted at the YSUS board.
                                          All IGBTs, the MOSFET K8A60DA and the diode D603 are shorten.
                                          So I replaced the parts. I checked the further parts for shorts and I was pretty sure that there is no further problem on the board.
                                          So I plugged it in. Directly, resistor R251 (2,2 Ohm) blowed out with a little spark. Immediately I disconnected the TV from supply.
                                          I checked the replaced parts (IGBTs, MOSFET...
                                          12-11-2022, 02:21 AM
