Hitachi P50S602 Powers On/Off Blue Light Blinks 5 Times
  • Robb
    • Sep 2013
    • 159
    My Hitachi P50S602 plasma powers on with that familiar white snow static then powers off after a few seconds and the power indicator blue light blinks five times & repeats. All the capacitors and resistors look fine. The fans also turn on and Vs & Va voltages are correct for the few seconds that it has power. When I unplug XSUS from the PSU, the tv does not power on at all and the blue light blinks 3 times. The only fuse I've found (on PSU) is good.
    According to the service manual (PDP panel self diagnosis), the blue power indicator light blinking five (5) times means: 1st possible cause - ADM, ABUS; 2nd possible cause - XSUS, Logic, PSU.
    I am not sure what ADM is or how to test it, ABUS or Logic. The static is also throwing me off too as it looks like it's not getting a signal, but I have tried a few different inputs along with trying to change the inputs modes.
    Does anyone have any similar experience with this or similiar tv or have any ideas on what to check next? Thank you in advance.
  • Sparks88
    • Sep 2011
    • 110
    Re: Hitachi P50S602 Powers On/Off Blue Light Blinks 5 Times
    ysus and the 2 largest caps on power board in uk they are rated at 400v maybe different in US
      ABUS runs the length of the plasma panel. It has the address/data drivers on it which are bonded to the panel and non-replaceable. If it is true ABUS fault then it may be a bad panel.
      • Robb
        • Sep 2013
        • 159
        Thanks for the responses. I think I figured out that ADM stands for Address Driver Module, but I don't know where it is located (not identified in service manual) or how to test it. There are six ABUS panels, three on top and three on bottom and all are connected to the panel by ribbons. The top row and bottom row are connected to each other and both are powered by the XSUS e.g. XSUS>ABU-UR(upper right)>ABUS-UC(upper center)>ABUS-UL(upper left).
        If I unplug the power from ABUS-UC>ABUS-UL and press the power button, the panel starts to display what kinda looks like deep space snow and then shuts down (no change/original problem). However, when I unplug ABUS-UR>ABUS-UC and press the power button, the display doesn't start or show anything; the blue led just blinks three times & repeats.
        Not sure if that proves anything, or not; other than I don't know what I'm doing
        • Robb
          • Sep 2013
          • 159
          Weird, I've only been able to find one guy on the web who claims to know how to "fix" Hitachis. He used to be a Hitachi repairman and he said all they do is swap boards until it works. Not very practical from a do-it-yourself perspective, imo. I guess I'll probably end up putting it on craigslist since the prospect of replacing ADM (whatever that is), ABUS, XSUS, Logic & PSU is out of the question, especially, considering it's age. However, at this point, smashing it into pieces might be more rewarding. I wish the screen never displayed anything, it would be alot less frustrating.
            I understand your frustration. I have never willingly tackled a big Hitachi, they are buggers to troubleshoot. I've worked on a few older 37/42" Fujitsu-Hitachi plasma panels in Philips plasma TVs though, but they're a lot different. I highly suggest you do not smash the panel... because then it truly will be worthless!!
            • Robb
              • Sep 2013
              • 159
              I decided to put the back cover back on and walk way for awhile. Perhaps this will be a great learning catalyst for me. I'm going to brush up on testing capacitors, transistors, resistors, etc. Hopefully, I will discover a common sense approach that will evince the fault despite Hitachi's proprietary interests. I hope to be able to report back, soon. Cheers
              • Robb
                • Sep 2013
                • 159
                Below is a picture of what the panel looks like for the three seconds before the TV shuts itself off.
                  Looks like PDP maldischarge could be Y-sus fault.
                  • Robb
                    • Sep 2013
                    • 159
                    Hmm, according to the service manual (p. 27), the five blue led blinks indicates 1) ADM, ABUS 2) XSUS, Logic, PSU.
                    Unfortunately, I don't think this model &/or brand accommodates the remove the Y-sus and see if it powers on correctly method of diagnosis. If I disconnect the Y-sus power, the blue led blinks three times & the screen displays nothing & the fans don't spin for the usual three secs before it shuts down.
                    I guess I should start testing the components on the boards soon. Do you know what components usually go bad on Y-sus & X-sus boards?
                    I'm not sure if this is important, but there is a burnt smell & slight discoloration on the underside of the X-sus around the R154, R155, R156 & R163 resistors (see pics), however, they all have the same ohm reading in circuit & one measured correctly out of circuit.
                    Thank you for your continuing input, Tom...it sure helps to bounce ideas off someone with experience.
                    • Robb
                      • Sep 2013
                      • 159
                      I finally found a way to get the blinking light to stop. If I unplug the Logic Board and hit the power button, the TV's LED turns solid red, then, solid blue, then turns off without ever blinking. Does anyone know if that means the Logic Board is defective? When I unplug any other board, the only thing that changes is the number of blinks.
                        The logic board will likely be involved in detecting many of the faults so no it does not necessarily indicate the logic board is the cause.
                        • Robb
                          • Sep 2013
                          • 159
                          Thanks. Is there a way to test it? The Logic Board is indicated as a possible cause of failure according to the five blinking LED code.
                            Without schematics not really.
                            • Robb
                              • Sep 2013
                              • 159
                              Guess I'll assume the Logic Board is good. (Facepalm)
                              • Robb
                                • Sep 2013
                                • 159
                                I know I'm grasping at straws but I found another anomaly. There are three HDMI ports and I plugged a playstation into all of them to see if anything would happen. Two ports did nothing new, just the usual power on with multcolored maldischarge. However, one port produced a partial image (see below). Could this mean there is an issue with the Main Board?
                                  It probably indicates the TV was originally set to that HDMI port and that bright image information can be displayed. I would be thinking more Y-SUS than X-SUS in this case but I'm not certain.
                                  • Robb
                                    • Sep 2013
                                    • 159
                                    Yes, that would make sense. Are there particular components that usually go out on the Y-SUS that I could check to see if it is in fact the Y-SUS? The TV is not staying powered on when I unplug the Y-SUS or X-SUS. Thank you for your faithful assistance Saint tom66!
                                      I have little experience with Hitachi plasmas. You could use an oscilloscope to test the output of each board.
                                      • Robb
                                        • Sep 2013
                                        • 159
                                        I guess it's time to get an oscilloscope. Do you know if the USB 2 channel models work well? They seem to be the cheapest...sure wish there was a hackerspace in my area, like Noisebridge in San Francisco.
                                        Edit: I guess I could just use the vertical coil wires from a CRT TV http://www.instructables.com/id/How-...-Oscilloscope/
                                        • TurboTundra
                                          PS5 EDM-033 Blue Light 2 Sec then Powers Off
                                          by TurboTundra
                                          Hi, I am waiting for my uart tool so I can grab an error code and narrow down where my issue is, but I decided to measure capacitors and fuses to insure everything was okay.
                                          The PS5 turns on with a blue light and a beep for 1-2 seconds then turns off. I noticed a grey capacitor measures no voltage on standby or input power. Does this indicate a problem with the capacitor or something down on the line? I’m getting 3.3v on input with the red cap next to the grey one, and 5.2v on input with the red cap further away from the grey cap.
                                          Thank you for any input...
                                          06-10-2025, 08:51 PM
                                        • nobbnobb1
                                          Panasonic TC-P50U50 Powers Off - 8 blinks
                                          by nobbnobb1
                                          I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                                          2x DG302 (Q16051)
                                          2x RF2001 (D16041)
                                          2x 5.6 ohm SMD resistor
                                          1x BD8694 IC
                                          I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                                          03-21-2023, 08:33 PM
                                          Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:50 AM
                                          Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
