LG 42PG60UD - Clicking & cycling on/off
  • Amraks
    • Nov 2011
    • 725
    Hey guys
    Model: LG 42PG60UD
    PSU: LPX54
    Mainboard: 60PG30UD-AA
    Have disconnected the Y-sus and The Z-Sus. The symptoms are still there.
    So I figure its not the Y-sus or Z-sus.
    It cycles about 4 times then stays on with a faint picture.
    Remote won't change the channel or turn tv off. the remote does make the led blink as if its communicating with TV.
    If anyone can help that will be great.
    I have attached a photo I found of the same PSU.
    as I haven't got my parents camera at the moment.
    Readings I have.
    VS: 181v
    VS: 181v
    VA: 59v
    VA: 59v
    It's writting on the tv what these should be
    VS :187
    VA:60
  • Amraks
    • Nov 2011
    • 725
    Re: LG 42PG60UD - Clicking & cycling on/off
    Just disconnected mainboard and shorted the Auto_gen now I have a test picture.
    So this could mean a faulty main board?
      That would make sense.
      Is this an LG plasma, with a Samsung power supply?!
      • Amraks
        • Nov 2011
        • 725
        Yes its a samsung psu
        Yes its a LG plasma
        Why do you ask?
          Well, it's unexpected. It's the first I've seen like that. I rarely see any Samsung parts in LG sets and vice versa -- I think the companies being such fierce competitors rarely buy from each other.
          It does seem like your main board is at fault.
          • Amraks
            • Nov 2011
            • 725
            yeah its uncommon lol.
            I think I have figured out why though, I rang LG and got the number for statewide they are LG spare parts, Samsung Parts and Panasonic Parts.
            http://www.statewideapp.com.au
            So get a new main board?
            or try find the fault?
            • Amraks
              • Nov 2011
              • 725
              5v_det: 4.7v
              av_det 4.6v
              not sure if these mean anything.
              should they be reading 5v?
                Those both appear to be OK.
                You can check LDOs, switching regulators, etc.
                Also, if you can, try checking the RS232 output and see if a message is output.
                • Amraks
                  • Nov 2011
                  • 725
                  what message output will it be?
                  Will it be along the lines of the software loading?
                    I don't know, I've never tried, but there may be -something- on the output.
                    • Amraks
                      • Nov 2011
                      • 725
                      Ok got the readings for the voltage regulators.
                      IC1003
                      EH16A
                      819F25
                      1. 0.00
                      2. 3.27
                      3. 5.05
                      IC803
                      6F
                      B26
                      1. 3.27
                      2. 0.00
                      3. 3.25
                      IC1004
                      EH13A
                      825F07
                      1. 0.00
                      2. 1.78
                      3. 3.30
                      Are these fine?
                        #2 probably isn't a regulator. Others are fine.
                        • Amraks
                          • Nov 2011
                          • 725
                          I thought that much
                          I wasn't sure as it was my first time testing this kinda stuff.
                          • Amraks
                            • Nov 2011
                            • 725
                            LDO's next?
                            Not sure what these look like.
                            Thanks heaps for helping me you are always helping around here.
                              LDOs = low drop out regulator, same as regulator, different name.
                              • Amraks
                                • Nov 2011
                                • 725
                                ok so I have done these hmm whats next
                                  Can you post an image of the main board?
                                  • Amraks
                                    • Nov 2011
                                    • 725
                                    not the best photos but what can you do when you don't own a good camera.
                                    I thought I would throw in 3 for good luck.
                                    • Amraks
                                      • Nov 2011
                                      • 725
                                      Hey not sure if this helps but its the mainboard diagram.
                                      • Amraks
                                        • Nov 2011
                                        • 725
                                        should I take a gamble and recap a few caps on the psu?
                                        or just buy a new mainboard?
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • high-tech
                                          Samsung UN55F7050AFXZA ver. TD01 power cycling
                                          by high-tech
                                          Hello everybody, I could use some help on this one... It's got me guessing...
                                          I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                                          (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                                          (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                                          (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                                          (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                                          9. ground (PWM2) 10. 0.9 volts cycling...
                                          09-15-2020, 03:39 PM
                                        • Salvatore057
                                          plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
                                          by Salvatore057
                                          I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
                                          Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
                                          I am lost, should I change the YSUS board? Is the YSUS board damaging...
                                          04-29-2018, 01:29 PM
                                        • usbdevice
                                          Acer X223HQ (Version Bbd) on/off-power-cycling
                                          by usbdevice
                                          Hi all
                                          There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                                          https://www.badcaps.net/forum/showthread.php?t=50657
                                          https://www.badcaps.net/forum/showthread.php?t=40512
                                          The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                                          It's my dad's old monitor. He...
                                          08-05-2022, 02:21 AM
                                        • JDC
                                          LG 60PB6650 - Bad ZSUS (3.8v to YSUS instead of 16v)?
                                          by JDC
                                          Make and Model: LG 60PB6650-UA
                                          Issue: Turns on, no backlight, can hear static (no channel)
                                          I've been repairing TVs for a couple years now. I know how to use a multimeter for the most part and know how to test most components for shorts.
                                          The power board connects to the ZSUS and then connects to the YSUS. The ZSUS is where I believe the failure is because the 16v line is only 3.8V, even when I disconnect the ZSUS from the YSUS.
                                          This particular model seems to have a common failure with its YSUS. My goal earlier was to prove the YSUS was bad so I could...
                                          09-13-2018, 02:12 PM
