LG 42PG60UD - Clicking & cycling on/off
  • Amraks
    • Nov 2011
    • 725
    Re: LG 42PG60UD - Clicking & cycling on/off
    http://www.ebay.com.au/itm/MAIN-BOAR...item43c07dedc3
    Would this work.
    I may have to cut some stuff out off the case but this board looks to have same connections hmmm
    Thought this might work but seems the ctrl boards are different.
      If the CTRL boards are different, no guarantee at all.
      • Amraks
        • Nov 2011
        • 725
        yeah not going to risk it.
        I will just wait for ebay to hand out its fate.
        • Amraks
          • Nov 2011
          • 725
          I have just contacted someone with a non-working same tv on ebay.
          Asked what their symptoms are
          Theres seems like a PSU problem, cause its not turning on full stop.
          So I am buying the psu and mainboard.
          Buying the PSU to cover my butt, if the mainboard is faulty.
          The rest I am going to kindly help them get rid of.
          Z-sus and Y-sus and controller board Y-driver board.
          • Amraks
            • Nov 2011
            • 725
            Well guess what this gamble paid off.
            The main board I bought works, inspected the PSU I also bought at the sometime as warranty as they are usually easy to fix if faulty.
            It was a blown fuse on his PSU.
            So Discovered mainboard has a different arm chip to genuis one.
            So I don't know if this fault will occur again. Hope not.
            • Amraks
              • Nov 2011
              • 725
              so I forgot to add TV works again.
              • astal
                • May 2022
                Hi @Amraks.
                Hope you are doing well. I realize this is a 9 year old thread but .... will give it a shot ;-) Do you by any chance have a complete service manual for the LG 42PG60UD? I have an LG 42PG20D that has the same main board (one less HDMI port soldered on).
                Thank you.
                • beetle1303
                  Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                  by beetle1303
                  I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                  On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                  01-13-2025, 08:49 PM
                • high-tech
                  Samsung UN55F7050AFXZA ver. TD01 power cycling
                  by high-tech
                  Hello everybody, I could use some help on this one... It's got me guessing...
                  I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                  (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                  (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                  (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                  (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                  9. ground (PWM2) 10. 0.9 volts cycling...
                  09-15-2020, 03:39 PM
                • Sisko
                  Onkyo-593 No power and now clicking sound
                  by Sisko
                  Hi all!!
                  Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                  10-03-2025, 02:18 PM
                • usbdevice
                  Acer X223HQ (Version Bbd) on/off-power-cycling
                  by usbdevice
                  Hi all
                  There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                  https://www.badcaps.net/forum/showthread.php?t=50657
                  https://www.badcaps.net/forum/showthread.php?t=40512
                  The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                  It's my dad's old monitor. He...
                  08-05-2022, 02:21 AM
                • PlasMatt
                  LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                  by PlasMatt
                  I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                  09-20-2025, 06:50 PM
