Adding capacitors to video cables?
  • Fizzycapola
    • Oct 2006
    • 423
    About 17 years ago a friend of mine bought a games console from an amateur electronics enthusiast. The lead that came with it (RGB SCART) had been modified (on the end that goes into the TV) with capacitors soldered to the pins inside. I wonder what is the purpose in this, from what I remember the picture quality was pretty good and vibrant using the lead compared to others.
    Rubycon Rubycon Rubycon
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Adding capacitors to video cables?
    How those caps where conected? Usually there are two reasons to put caps on cables: to isolate the cables galvanically, to avoid hum or ground loops (you have to cut the wire and bridge them with the cap)
    Or to short certain AC frequencies to ground, depending on the value (the lower, the higher the frequency wich is shorted) in soldering the caps from the signal wire to ground.
    • Fizzycapola
      • Oct 2006
      • 423
      Well I have no idea whatsoever about this. All I know is the picture & sound quality from the lead (RGB SCART 21 pin) was legendary compared to normal leads without capacitors in, it may have had other components inside too, it's all long long ago now though it only exists in me and my friend memories.
      • starfury1
        • May 2006
        • 1256
        sort of vaguely remembered something about that but anyway did a search
        it basically tweaking the video sig RGB (chroma) whatever, according to this site by boosting?
        from this thread I found here
        The original mod link is dead.
        So you will have to search for it if you want it
        heres another link
        this one talking about removal of caps with different consoles, and other stuff
        Yet to find a good technical explanation link of it all
        Like Gonzo0815 technical answer above.
        As soon as you have a capacitor and some resistance you got a filter of some kind,
        just depends on it and what you are feeding it to the results you get at the output
        (Gonzo0815 has more or less said this above)
        I have a funny feeling that caps in series will cause a peak in bandwidth response
        at some point so this may be why its more vibrant
        but I will stand to be corrected on that....
        I would say it somewhat dependent on whats feeding it circuit wise too.
        Do you remember which game console it was, just out of curiosity?
        Ok didn't really read this, its about modifying a sega for RGB SCART here
        Looked interesting
        Not the exact answer I think you were looking for but Hope it helps
        Cheers
        You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
        • Fizzycapola
          • Oct 2006
          • 423
          It was a SNES scart lead, I think oem, the end unscrewed and there were capacitors inside.
          There was another SNES scart lead, more common it had capacitors and a switch for maximising the picture quality to compensate for different TV brands. (not related to 50/60hz or composite/rgb switching)
          I spoke to my friend recently, he says he may be able to find this lead, but it may be sometime before he finds it. I'll post some pictures soon hopefully.
          • starfury1
            • May 2006
            • 1256
            Yeah, as I said vague memory of something about it which is why the search....
            (never had much to do with scart or SNES....)
            As I suspected the info was going in a little different direction to what you were talking about.
            Sounds interesting thought, hope your mate can find it.
            Cheers
            • Logistics
              • Apr 2007
              • 721
              That same site explains that the NTSC versions of the SNES had a DC offset on the R, G and B lines. It's standard practice to use at least 220uF caps as part of the coupling filter to remove it. The VGA box for the Dreamcast had the same thing already built into it.
              Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
              • Tom41
                • Oct 2005
                • 336
                • England
                I've seen caps inside SCART leads before. The RGB SCART lead I had for my PSOne had caps soldered to the Red, Green and Blue signal pins for some reason. Apparently it's to adjust the black level of the picture; without the caps all black areas would appear gray.
                The switch you mention on the RGB lead may just be for switching the RGB signal on and off. Most TVs with a SCART socket 'listen' for a voltage on a certain pin - if present, it puts the TV into RGB mode. If the voltage is not present, it uses composite-only mode.
                That may explain why this lead provided a more vibrant picture; it was passing through the RGB switching voltage. The other leads might not have been doing that (I have one for Sega Saturn that doesn't pass it through), and therefore the picture would have been composite.
                From worst to best picture quality, the connection types for games consoles are as follows:
                RF - Composite - RGB SCART - Component - HDMI
                You know there's something wrong when you open your PC and it has vented Rubycons...
                • Logistics
                  • Apr 2007
                  • 721
                  Actually, RGB+HV is video's native format; this cannot be bested. No matter what your display, everything has to be converted back into this format in analog form for the screen to display it. It is superior to everything.
                  If manufacturers included pure RGB inputs and outputs on their products, that would make Macrovision sad because it's impossible to implement copy protection over pure RGB.
                  • shadow
                    • Feb 2007
                    • 732
                    [If manufacturers included pure RGB inputs and outputs on their products, that would make Macrovision sad because it's impossible to implement copy protection over pure RGB.
                    Now wouldn't that be great to see!
                      HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                      This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                      09-12-2024, 02:00 PM
                    • ohren
                      Pinout of LG 4 pole 3.5 mm component video cables?
                      by ohren
                      I hope this forum is appropriate to ask about pinouts for tv manufacturers.
                      So I just acquired an LG 42LE530N and noticed it uses a 3.5 mm jack for component video. To confirm component input working I dug out a 4 pole 3.5 to RCA camcorder cord and tried all configurations before realizing that GND must not be on pin 3.
                      Is there a standard pin out for this? Or is it LG specific?
                      What is it?
                      It's easy enough to find pin outs of 3.5 mm composite AV, but couldn't seem to find any for component video*. Maybe I looked in the wrong places.
                      02-25-2023, 08:39 AM
                      GeForce RTX2080 Super Aero video gaming card issues help need
                      by sam_sam_sam
                      This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                      Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                      05-07-2023, 08:12 AM
                      HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 1000 Specification for Upgrade or Repair
                      This specification for the HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                      09-06-2024, 06:20 AM
                      HP ProBook 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
