LCD1502DVD 15" TV - No Power
  • pyrosster
    • Aug 2013
    • 43
    • Spain
    I am trying to troubleshoot a 15" TV that does not turn on, no sounds/relays, etc. dead.
    I checked power supply and there's a broken "resistor fuse". (picture below) What's the value of this "resistor fuse"? 56 ohms? Can I change this with a normal resistor?
    Power supply is 12V 5A.
    Thanks for any opinion or insight
    Re: LCD1502DVD 15" TV - No Power
    Is that device original? Could it have been accidentally incorrectly replaced?
    A 15" LCD TV would use about 2 amps on 12V. The 56 ohm resistor would allow an absolute maximum of 12V/56R = 210mA. Therefore, I doubt it is 56 ohms. A value of less than or equal to 0.56 ohms would be expected.
    • pyrosster
      • Aug 2013
      • 43
      • Spain
      Thanks tom66 for your reply.
      The device is original. It's a 15" TV with DVD player. So the fuse resistor could be changed with a 0.56 ohms 1/2W normal resistor?
      The sticker on the PCB (250V/6A) is confusing because the power supply is 12V and the part AZ1084S2 is a low dropout linear regulator.
      Thanks again.
        Does the 12V output from the power jack go anywhere else?
        • pyrosster
          • Aug 2013
          • 43
          • Spain
          It's very strange. The chassis have this sticker: Power input: 110V-240V 50/60Hz 48W
          But the mainboard only have a 12V connector and the transformer sticker is 12V 5Amp.
          The manufacturer changed the design?
            Probably printed many stickers and decided to use them anyway..
            • pyrosster
              • Aug 2013
              • 43
              • Spain
              tom66, how can I replace that part? Normal 0.56ohm 1/2W resistor is ok?
                I think a fuse will work, I still don't think that's an original part...
                • pyrosster
                  • Aug 2013
                  • 43
                  • Spain
                  What type of fuse? which value?
                    I usually take 1.5~2x input current so 7.5A to 10A that being said a 15" would normally not use more than 2 amps so maybe 3 to 5 amps rating. Slow blow type.
                    • pyrosster
                      • Aug 2013
                      • 43
                      • Spain
                      Thank you!
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                      • gica69
                        Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                        by gica69
                        I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                        Resistor shows orange range silver gold and green lines.
                        Thanks in adv...
                        07-21-2025, 09:49 PM
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
                      • JimBanville
                        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                        by JimBanville
                        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                        09-13-2023, 07:21 AM
