Samsung LE40M86BDX main Board compatibility
  • jbfr_54
    • Dec 2012
    • 52
    • France
    Hi All,
    I have a Samsung LE40R86BDX with a faling main board BN94-01206B.
    I cannot find a spare one but have been told that board BN94-01490R is compatible and I can find several of them.
    Does any one know about this compatibility.
    Regards.
    Jean
  • jbfr_54
    • Dec 2012
    • 52
    • France
    Re: Samsung LE40M86BDX main Board compatibility
    Sorry I conform it's a LE40M86BD as mentioned in the titel.
    Rgds. Jean
    • truep
      • Aug 2010
      • 373
      Check shopjimmy.com they usually list compatible boards and I've had good luck with their recommendations.
      • Asraf Atb
        by Asraf Atb
        01-27-2025, 05:02 PM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        Yesterday, 08:34 AM
      • Lee M.
        Samsung UN75RU8000FXZA bad main board?
        by Lee M.
        When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
        11-08-2023, 07:46 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
