Is this likely a panel problem, or something else?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Is this likely a panel problem, or something else?
    What you'll find, is that chip pair--on its ally plate--will get much hotter than the others....
    This is a sure sign of failure.
    No cure I'm afraid--panel replacement, For some reason Ive had three 42 PX 60/600 with those chips faulty. All the same day practically!
    --Seems its a common issue with those 42" Pans of that series.
    The 37" seems more reliable, not had one fail on one of those yet....
    TELEFIX
    • perzyk23
      Lenovo T580 - LCD Panel problem - error 0288
      by perzyk23
      Good morning,
      I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
      10-25-2024, 12:42 AM
    • porfyriadhs
      LG 49UJ701V Panel problem
      by porfyriadhs
      Hello I have a tv with bad panel
      Brand LG 49uj701v. At first screen wasnt working only sound with backlight was working welll. The I tried tape at the lvds and it works but I get have image with shadoe
      10-05-2024, 06:18 AM
    • Davi.p
      Sony KDL-42W705B panel problem
      by Davi.p
      Hi, this has panel problem for certain (AUO panel), in the troubleshooting process, after pressing ON button i am with set making a short lamp of backlight with status light shortly white then green/yellow repeated, in this situation main board remain powered and also tcon with all their correct output voltages. I cant find in the service manual description of this state, can you brief me ? thanks
      01-26-2023, 07:56 AM
    • Storyteller12
      QN55Q60R Service Menu Panel Help
      by Storyteller12
      I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
      I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
      I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
      the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
      01-13-2024, 01:57 PM
    • maneatingmonkey
      Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
      by maneatingmonkey
      I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
      There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
      03-27-2024, 07:17 AM
