Sony KDL40S2000
  • Horty24
    • Oct 2011
    • 54
    Re: Sony KDL40S2000
    0.6 Ohms is the reading on all top inverter 10 MOSFET.
    The lower board is on Mohms at 2.3 now and dropping.
    Now the blown fuse is still on the board. Should I replace and get new readings with good fuse?
    • TheHacker
      • Sep 2013
      • US
      Re: Sony KDL40S2000
      Looks like I know who got the $40 TV. So it was a bad inverter/backlight problem, when I first saw the photo I assumed a bad panel.
      • Horty24
        • Oct 2011
        • 54
        Re: Sony KDL40S2000
        ? Wrong buyer, I'm the original owner.
          Re: Sony KDL40S2000
          No need to put any new fuse in right now, you have really bad shorts that draw more than 10A, so how many MOSFEs are there on that top board. You may want to shop around for the new board also.
          • Horty24
            • Oct 2011
            • 54
            Re: Sony KDL40S2000
            There are 10 MOSFET on the top board. I actually just finished putting in the new fuse. Any more ideas prior to looking for a new board?
              Re: Sony KDL40S2000
              If I were you, I would replace all 10 Mosfet and all the electrolytics caps at the same time, bad caps can cause the MOSFET to draw too much current and get damaged due to high AC ripple on the DC power feeding the circuits. I would replace the caps on the bottom also.
              • Horty24
                • Oct 2011
                • 54
                #27
                Re: Sony KDL40S2000
                Replaced inverter boards and now working like new.
                Thanks for everyone's help.
                • caseyjay_48
                  Sony KDL-46BX450 Inverter Troubleshoot Logic
                  by caseyjay_48
                  I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                  I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                  09-23-2022, 08:08 PM
                • Watson306
                  6 Red Blinking lights (left side darker) on Sony KD-49XE8396
                  by Watson306
                  I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
                  I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
                  I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
                  Many Thanks in advance.
                  11-01-2022, 05:33 AM
                • Carlos#2003%
                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                  by Carlos#2003%
                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                  02-15-2024, 07:52 PM
                • dkneyle
                  Sony KDL-46HX850 Can't upgrade/update firmware
                  by dkneyle
                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                  09-25-2024, 10:44 PM
                  Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                  This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-06-2024, 05:27 AM
