Pioneer PDP-R05G media receiver always starts in standby mode
  • vicki007
    • Sep 2013
    • 5
    • india
    I have a Pioneer Plasma and PDP-R06G Media receiver. When I power on Plasma TV with everything disconnected except the power cable, it starts flashing alternate red and green rectangle boxes on the screen which seems normal to me as no system cable is yet connected to it. But when the black system cable is connected to the media receiver ( media receiver not yet powered on), Plasma goes into standby mode with the red standby led constantly on and nothing is displayed on the screen. Now, if media receiver is powered on, it starts with standby led glowing and the fan at the back of the receiver stops after about 5- 7 sec. If I try to display the menu using button on the remote control, nothing is displayed on the screen. I tried to unsuccessfully factory reset the system. What can be the issue? Is it to do with the media receiver or the TV?
    Thanks.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Pioneer PDP-R05G media receiver always starts in standby mode
    Try testing the tv with a different video/audio source. If the TV works fine, it is the receiver that has an issue.
    Muh-soggy-knee
    • vicki007
      • Sep 2013
      • 5
      • india
      Yes. TV is working fine when different source is used. So, the issue is with the receiver. Now, what can go wrong with the receiver? How can I diagnose the problem? Is it something to do with power supply board?
      Thanks.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        hi if it was me i would try doing a hard reset of the media box to put it back into default settings and try that for a few days you may have to download a user manual or look on line how to do this.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Thanks.
          No, it still could be the TV. You need to test the same input on the TV that the receiver is hooked up to, not other inputs!
          Muh-soggy-knee
          • vicki007
            • Sep 2013
            • 5
            • india
            As I said in my earlier reply, I tried to hard reset it but did not succeed as remote control is not working when TV is connected to the receiver. Only the power button on the remote is functioning. If there is any other method to hard reset it, I would be more than happy to have a go at it.
            I borrowed the same type of receiver from a friend of mine and worked fine using the same inputs as you directed to do. Can the issue be still with the TV?
            Thanks.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              I doubt it. I am 95% sure the receiver is the issue.
              Muh-soggy-knee
              • vicki007
                • Sep 2013
                • 5
                • india
                Ok. So, what can go wrong with the receiver? The receiver powers on in standby mode (both the green and the red led glow simultaneously) and the cooling fan stops within 10 sec of starting the receiver. Can the issue be with the power supply PCB? Or is it something else?
                Thanks.
                • irep
                  • Oct 2013
                  • 40
                  • portugal
                  It can be the power supply, check ACSen what voltage it goes out
                  • truep
                    • Aug 2010
                    • 373
                    I think it's normal for the fan to come on for a few seconds, it did on my kenwood. Then it will come back on if the temp rises above a ceartain point. Are you using HDMI inputs/outputs?
                    • irep
                      • Oct 2013
                      • 40
                      • portugal
                      But you can check voltage from relay after fan shut down, if it goes out power board self protect.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Thanks.
                        Actually on that model media receiver the fan should run as long as its plugged in. It runs if it is powered up or in standby.
                        • RatherLoopy
                          Pioneer VSX-44 receiver HDMI dropouts
                          by RatherLoopy
                          I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                          I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                          And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                          05-26-2023, 03:54 PM
                        • tvguy12012012120
                          by tvguy12012012120
                          02-07-2025, 05:13 PM
                        • thetonywarren
                          Pioneer VSX-3300 Receiver Wont Power On
                          by thetonywarren
                          Have a colleagues Pioneer VSX-3300, it wont power on, hasnt for a number of years, but just now trying to figure out what's going on with it.
                          It has 120V input and I have followed that 120V to a small board that appears to have a small transformer and a relay among a few other components I dont think the relay is changing state which I believe turns on the receiver, but this is all speculation.....
                          I have downloaded the repair guide, which I have attached to this post, but I am having a hard time following it.... Can someone please offer any advice on what to check?...
                          12-28-2021, 01:26 PM
                        • chaos-theory
                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                          by chaos-theory
                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                          03-14-2025, 05:37 PM
                        • fharris1977
                          Vizio D50u-D1 Dead Set No Standby
                          by fharris1977
                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                          12-28-2023, 10:25 AM
