Sony Bravia KDL-32BX300 No Standby Light
  • kbrock
    • Jun 2015
    • 3
    • U.S.
    Re: Sony Bravia KDL-32BX300 No Standby Light
    I have this exact TV. We were watching it the other day and it just turned off. It will not turn on now. No lights or anything. Just acts like its unplugged. I unplugged it for a few hours and it still won't turn on. I thought maybe the power supply might be at fault. I read this thread and noticed statement about 2 fuses but I only see 1 where the plug cord goes to the board. I has full continuity so its not bad. I don't have any training or knowledge in electronics so I need help to move forward. Please Help !
    • coucouillu
      • Jun 2013
      • France
      Hi 1beertap,
      Do you have any feedback concerning the new board you bought?
      Thank you.
      • SkishyIshy
        Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
        by SkishyIshy
        Hey All,
        I have a Sony 65x900f that I purchased cheap because of a no-power issue.
        I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
        I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
        03-17-2021, 11:44 AM
      • androripara
        Sony Bravia 55HX820 - 4 times blinking red standby led
        by androripara
        i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
        I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
        Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
        10-19-2023, 05:16 AM
      • ChristianBr01
        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
        by ChristianBr01
        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
        04-23-2025, 01:48 AM
      • noinimod
        Sony 55X900E no standby light, no power. Replaced mainboard already
        by noinimod
        No standby red light, nothing
        This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
        Disconnected JK3 power board from main board, checked voltages on all the pin outs
        At a few pins I can see the power supply providing 19.5V to the main board
        Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
        LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
        12-22-2021, 12:58 AM
      • AleMonti
        LG 55EG910V - no power and no standby light
        by AleMonti
        I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
        I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
        The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
        After checking the basics I did the following:
        • I measured all voltages and as expected the only active supply is the 3.5V standby. It
        11-04-2024, 05:02 PM
