NEC LCD4000 weird backlight issue
  • reliantkcar
    • Aug 2013
    • 34
    • usa
    ok so got a real cheap NEC LCD4000 monitor
    it's a 2003 model and the first large LCD ever made supposedly
    it has 5 inverter boards
    when i looked at it it had the bottom 3rd was dim
    so brought it home and did some inverter swapping
    since the bottom 2 werent working
    first I swapped the 3rd one wit the6th and it didn't cjange so number 6 works
    then i swapped 4 with 5 and now 4 bulbs are on
    then the bottom one came on for 20 mins then died
    they all feed each other so when i put the bad bottom one in the middle it wouldn't power the ones below it so it's definetly bad
    am i correct in assuming the bottom inverter is bad when its cold it works and after 20 mins the bottom one shuts down
    also the bottom 2 bulbs are brighter than the other 3 so the bottom must have been off for a while
    Re: NEC LCD4000 weird backlight issue
    Can you show us some pictures of the chassis?
    • SuperJames
      Dell G3 17 3779 Weird power cycling and shutdown/restart issue
      by SuperJames
      This one's a weird one, and still unsolved despite it having gone back to Dell once.
      Specs
      i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
      Backstory
      I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
      10-23-2023, 04:09 PM
    • ugamazing
      820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
      by ugamazing
      So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
      1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
      2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
      04-10-2024, 08:06 AM
    • lukkihapsi
      Asus Vivobook X515JA Weird Boot Issue
      by lukkihapsi
      Asus Vivobook X515JA Laptop
      Issue :
      Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
      Tried :
      Cleaned inside for dust, applied fresh thermal paste. No Change!
      Removed keyboard, Trackpad, fingerprint sensor. No Change!
      Removed Internal SSD. No Change!
      Updated BIOS to latest version. No Change!
      Removed battery and pressing power button for 1 minute. No Change!
      Weird Part :
      Upon turning laptop ON, screen lights up - stays black,
      I...
      07-07-2025, 12:07 PM
    • Spider1211
      Weird but interesting issue with DELL 3542 (intel mb 13269-1)
      by Spider1211
      Hey guys, need help fixing a weird issue with DELL 3542 with board cedar intel mb 13269-1
      Schematic from here: https://www.badcaps.net/forum/showthread.php?t=52924
      Backstory:
      Laptop came in as completely dead. I opened it and removed the top half of the casing (as well as battery) and tried to power it again and it turns on and post. I turned it off, unplug charger, plugged back in and nothing. No boot, no nothing. I tried resetting CMOS but no dice.
      Power supply draw:
      Voltage: 19.40V
      Amp draw: 0.006 - 0.007A
      Amp draw...
      04-07-2021, 03:21 PM
    • tommygun26
      Hp 6510b weird issue
      by tommygun26
      Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
      02-26-2023, 06:00 AM
