vizio board compatability?
  • willyd93
    • Aug 2013
    • usa
    okay so I have a vizio e320-a1 and the sticker on my main board is CBPFTXCCB02K033001Q but i was wondering if the CBPFTXCCB02K033002Q is compatible they both come up on shopjimmy under my tv model but when I asked a live chat rep they said they are unsure but it may be.
    im just looking for a compatible mainboard any help would be awesome thanks.
    id also like to note my symptoms originally it would the led power light would turn on when i pressed the power button but tv was unresponsive no sound no display but now the power led isnt event turning on when i plug it in yet the board still has power going to it. im assuming a bad main board.
    Re: vizio board compatability?
    If:
    - the panel they came from e.g. LG ELECTRONICS LC320WX1 is the same (SJ will specify the panel in most cases) is identical, and;
    - the connections, layouts and mechanical dimensions are identical.
    Then it should work fine.
    • capkid
      • Oct 2010
      • 1339
      I was just looking at both boards on Shopjimmy earlier, and they are used in TVs with the same panel version. It does sound like the main board is bad. That looks like a tough main board to source.
      LG Plasma Mal-Discharge Correction Service
      • willyd93
        • Aug 2013
        • usa
        kool thanks i may just price out a broken screen tv for parts
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • JDC
          by JDC
          ONN 100012588
          Long answer:
          07-15-2022, 07:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
