searching for help for a polaroid TLX 04244B TV that will not turn on , but blinks seven times I have replaced the power board, but it still blinks seven times.
Tlx 04244b
Re: Tlx 04244b
This person had a similar issue - it turned out to be a bad main board. I'd follow the troubleshooting steps mentioned to see if you arrive at the same conclusion: http://www.justanswer.com/tv-repair/...lue-light.htmlLast edited by capkid; 09-04-2013, 02:03 AM.
by BiruslapioBought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner... -
...1 Photo11-20-2024, 08:52 PM -
by modtoolHi to all,
the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts... -
by Taurus12Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
Any recommendation on what I have to do next? Thanks in advance -
by jchonHi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
I found the service manual, which was critical to know where to probe.
https://www.manualslib.com/manual/20...1e-Series.html
With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
Unfortunately the 5-blinks... - Loading...
