Safely Discharging a Flyback Transformer.
  • Clydeuk
    • Jan 2012
    • 193
    Re: Safely Discharging a Flyback Transformer.
    You can make a tool to discharge the CRT using a wire with a croc clip one end, a highish value resistor (if you want to avoid the HV crack as it discharges) and an insulated screwdriver. Attach the end of the wire with the resistor to a metal part of the screwdriver, clip the croc clip end on the CRT GND (the aquadag connection, usually a braided wire around the bowl of the CRT). Slide the tip of the screwdriver under the anode cap to touch the connector (may be a spark), and leave it a while. The lower the resistor used, the faster the discharge (and the bigger the spark!).
    Be aware that CRT's recover some charge slowly, so I find it best to connect a lead with a clip each end into the eht connector cavity with the other end on the dag.
    The shock from a CRT isn't usually lethal but can be unnerving and if you're carrying a tube you could drop it or have some other disaster on being caught unaware.
    They changed the recommended procedure for discharging CRT's years' ago due to the shift to transistor sets. With valve equipment it was normal to just shove a screwdriver between the metal chassis and the anode as there were no delicate semiconductors that could be potentially damaged.
    All I used to do was remove the dag ground connection from the CRT base, squeeze the anode cap to allow it to be unhooked from the cavity, then holding the dag wire with a pair of insulated pliers approach the cavity until a spark jumped between the two, finally leaving the dag wire inside the cavity.
    • truep
      • Aug 2010
      • 373
      Back in the days when TV's used tubes ( valves for you all across the pond), The procedure was to discharge with a screwdriver under the cap of the CRT or at the HV rectifier tube You had to leave it there for quite some time after the spark snap, or you would bitten! for some reason quick short wouldn't do it. Guess how I know!!
      • retrotechrestoration
        Looking for a flyback transformer for an Eizo TX-C7 MA-791 17" CRT
        by retrotechrestoration
        I just saved this magnificent RGB input Eizo Flexscan TX-C7 MA-791 from the local e-waste...good news, the tube works and the board looks great...the bad news, it sounds like the flyback is shorted. (Turns on...perfect picture...systemic high voltage crackling heard while the picture flickers...then it blows the 5A fuse in my isolated A/C power supply.)
        Anyone have any leads on possibly finding a replacement? (photo shows the flyback model numbers)​...
        03-22-2024, 06:50 AM
      • bohaboha
        can a flyback transformer for USB charger isolate?
        by bohaboha
        can i use a flyback transformer from an usb charger to isolate galvanically a small diy led tester? or it must be an isolated transformer
        01-15-2022, 02:36 PM
      • ohren
        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
        by ohren
        Hello!
        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
        Measured voltages with no load:
        After rectifier diodes
        12V: 6.17 V
        5V: 5.67 V
        Secondary transformer pins AC measurement (really don't know if this says anything)
        12V: 2-2.5 V
        5V: 1.04 V
        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
        03-18-2023, 10:33 AM
      • mikey5791
        Is it possible for transformer substitution?
        by mikey5791
        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
        My questions are
        1. How do i test to see if the transformer is in good working condition?
        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
        Hope you guys understand what i was asking. My intention is...
        11-03-2022, 02:11 AM
      • dennis_elx33
        3PHASE STEP-DOWN Transformer in Check
        by dennis_elx33
        Hello All,
        i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
        Problem statement: Power tripped Off
        Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
        Action Done:
        1) Replaced the faulty parts with good spare.
        2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
        12-02-2024, 06:52 AM
