Samsung LN46A650A1F easy fix
    This 2008 Samsung 46" came in yesterday. Bad caps, of course.
    More pictures here:
    http://s807.photobucket.com/user/bud...?sort=3&page=1
    So far no tab bond problem showing up yet either.
    Re: Samsung LN46A650A1F easy fix
    Nice. I've had the LE40A656 with bad caps, and I stuck it in the front room at parents house... still going fine, no tab bond issue either.
    Did you replace all the caps? I did all on mine with Panasonic FR and FC.
      Yes, I replaced the 2 bad one first to see if I can get the backlights to come on first to make sure it does not have cracked screen, I replace the set of caps after the verification.
        I'd imagine you could still pull the power board cable to do the backlight check, even if caps are bad? After all inverter is primary side. Not sure how dependent it is on the power supply working OK, or if this model supports that test.
          That is what I did first but that did not work, It is the bad caps in the power supply (stby ps) is not supplying the pull up voltage to turn the PS_ON and the BL_ON signal, after new caps installed the backlights come out with the cable disconnected between the power supply and the main board.
          When I first turn on the TV before repairing, it was going on and off with Samsung chime, stuck in that mode.
            Or maybe inverter control circuit runs off 13V rail. Not sure if it is separate rail or shared.
            I see Samsung did not bother with fan for cooling the motion FRC on t-con on this model. The t-con on one I did failed even with that fan blowing air over it.
            • tibimakai
              • Jan 2012
              • 3680
              I have the same exact TV and after replacing all the capacitors(except the two large ones), it's working for a while and then the backlight shuts down, but everything else it's still working.
                You should probably start a thread if you haven't already.
                • tibimakai
                  • Jan 2012
                  • 3680
                  I have one already.
                    Look at the FB and LD signal.
                    LD = 10~12V
                    FB = 0 V
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I will look for that. Thanks. It's so hot in the garage, that it may take a while until I will get back.
                      Here is my thread:
                      https://www.badcaps.net/forum/showth...hlight=samsung
                      I think that it's not a good idea to run the TV without the back metal cover. I keep a fan over those boards while I'm waiting for the backlights to turn off.
                      Because of the heat, I slowed down on TV repair and trying to repair Kenwood double din units, with not much success. I'm not getting any help in the audio forum.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Actually, I have that info already in my other thread, post #11.
                          The metal cover is only for EMI. i.e. you could annoy the HAMs by leaving it off, but it won't affect the TV's operation.
                            09-07-2024, 05:50 AM
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 06:20 PM
