Pana plasma TH-50PX75U shutdown 10 blinks
  • hienton2
    • Sep 2009
    • 183
    I am working with Pana plasma TH-50px75U. Tv led blinks 10 times after power button pushed.
    I did trouble shoot as service manual. It said power board is bad.
    I check power board and see Vsus and Vda from Mc701 never send signal to turn on Vsus and Vda.I check thermal fuse of T201 is good.
    Any body have idea to fix this . Thanks.
    Re: Pana plasma TH-50PX75U shutdown 10 blinks
    10 blinks can be main board too. Check the 3.3V, 1.8V, 1.2V etc on main board.
    Guides: http://www.tgohome.com/ServiceManual...Search=Submita
    • hienton2
      • Sep 2009
      • 183
      Thanks Tom.
      Source 1.2, 1.3, 3.3 in A board all good. May be I need P board EtxMM655MEH. expensive part
      • ajshoe
        ajshoe
        • Dec 2012
        • 477
        • usa
        Have a pana th50PX77u thats completely dead (apply power - no clicks or lights) - PSU etxmm655meh. does anyone have any diagnostic or repair tips for this PSU ?? I've seen a blog that says replace MC201, MC301 and maybe IC tea1610. Thanks
          Are fuses OK on your board? You should really start a new thread.
          • tw2005
            • Oct 2011
            • 6458
            Not sure if the troubleshooting guide I have is exactly correct for this model. Do you have a copy . It's quite detailed.
            since it's dead, no clicks, says first step is
            1.Is there 5V at
            pin 5 of connector A7 when the
            TV is plugged into
            the AC line?
            NO to step 1
            Unplug the TV. Is there continuity between pins 8 and 10 of connector P12 of the P board?
            YES to 1
            Is
            there 3.3V at
            pin 6 of connector P7 when the
            TV is plugged into
            the AC line?
            What have you checked so far? Fuses?
            • ajshoe
              ajshoe
              • Dec 2012
              • 477
              • usa
              tried to start new thread - HOW ????
              no 5V at pin 5 of connector A7 when the
              TV is plugged into the AC line
              TV unplugged - 1 ohm continuity between pins 8 and 10 of connector P12 of the P board
              assuming the PSU is bad. looking for diagnostics on PSU - or what to look for ?
              • tw2005
                • Oct 2011
                • 6458
                probably is a PSU issue.
                Unplug the TV.
                Disconnect connector A7.
                Does the TV turn on by itself
                when it is plugged into the AC
                line with no picture and lit
                LEDs on SS & SC
                boards?
                If not then PSU.
                You have no STDBY 5v so I'd start with the fuses F601,602,501, thermal fuse RF601.
                manual and troubleshooting guide should be in Tom's reference library in the sticky.
                TRAINING MANUAL
                SERVICE MANUAL
                you should be able to start a new post from the front page.
                • ajshoe
                  ajshoe
                  • Dec 2012
                  • 477
                  • usa
                  thanks, TW2005 !
                  • jm1234
                    Panasonic plasma TX-P42ST50 - 6 blinks
                    by jm1234
                    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                    I checked that board for any obvious faults...
                    05-22-2024, 06:59 AM
                  • Alicat
                    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                    by Alicat
                    Stopped by this site trying to fix my parents Panasonic Plasma TV.
                    Model number is TH-50PZ85U
                    Power comes on and the red power light stays on solid.
                    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                    I also hear a few clicks.
                    I also think my parents said there was a thunderstorm and the TV failed after that.
                    Section 6 in the service manual talks about power and no screen,...
                    10-30-2024, 10:09 AM
                  • Caimano
                    hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
                    by Caimano
                    MB G7AD-2G DAG7ADMB8D0 REV D
                    Processor i5 8265U
                    AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
                    Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
                    Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
                    02-06-2024, 10:14 AM
                  • M80
                    Samsung PN51E550D1FXZA plasma no power up 2 blinks
                    by M80
                    Samsung model # PN51E550D1FXZA plasma TV after a lightning hit (LAN cable was connected to TV). Standby LED on ok, but when pressing the power button, getting 2 blinks on the red LED, the screen flashes white for a second, and then cycles through this loop routine.
                    ALL voltages Vs, Ve, Vsc, Va check ok at SMPS output pins and at Main Board connector and X/Y drive board test points.
                    Noticed the Logic Board LED lights up green for a couple of seconds, hums lightly, then goes off during this cycling.
                    I've reseated ALL connectors and none of the boards have any burned traces or...
                    08-11-2022, 04:34 PM
                  • nick31
                    Panasonic Plasma ST50 TC-P55ST50 P55ST50 8 blinks
                    by nick31
                    My Oct 2012 panny plasma quit working yesterday.
                    It was on when it happened. It let out a bit of burned plastic/circuit board smell. I was not able to find any burned parts though.
                    Now it produces 8 blinks. According to the repair manual, that points to SS/SS2 board(s).
                    I completed the steps in the guide: unplugged SS33, the TV turned on with a black screen, no blinking codes. Then I checked the continuity between pins 1 and 2 of the connectors SS52, SS54-SS57. The continuity is ok in all of them. Guide suggests to replace SS/SS2 boards so I placed an order...
                    04-21-2021, 09:56 AM
