Schematic for Westinghouse SK-32H540S
  • jesselyons2002
    • Jul 2013
    • 82
    • usa
    I was wondering if anyone had the schematic Westinghouse SK-32H540S power supply board 0500-0412-0940, PLHL-T836B. Cause the power supply board has two new inverter and I recorded the voltage on all the wiring going to the screen and getting 400+ volts when the screen is lit but then the volts drop down to 4+ volts when the screen goes off.
    Too me thats a big voltage drop. I was wondering why it was going down so much or what is switching to a lower volts
    I do know this tvs are know for bad inverter boards due to bad inverters blowing and the tv screen going off after 10 seconds. Even when you add new inverter. The screen still goes off after 10 secs.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • alro7779
    Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
    by alro7779
    Hello, guys!
    I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
    Alex....
    10-03-2025, 05:49 PM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
