samsung UN46c5000QF
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    samsung UN46c5000QF
    Hello all...
    Was hoping the excellent experts here could help me diagnose this TV.
    When plugged into the wall outlet,the red standby light is on.When a attempt is being made to turn the TV on via remote or on TV itself,the red light disappears for a split sec and comes back on and stays on solid.No clicking sound from TV.Every so often the red light goes off,then on,then back off and to stay on after that at a turn on attempt.
    So far I have removed the cover and measured all the fuses on the power board,they are all ok,I don't see any "bulging/leaking" caps....
    When I remove both plugs from the powerboard,the standby light doesn't even come on.
    Would be very interested in suggestions what to try next
    I have a digital meter and some basic knowledge of electronics(many many yrs ago when boards where simple)...
    Thank you in advance for your time and expertise....
    Martino
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    Re: samsung UN46c5000QF
    Near the power connector which goes to the main board (from the power board) there should be a label, indicating what pin does what, what does this label show?
    Fast track guide by Samsung:
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      Thank you for the fast reply
      I took 2 pic's,one from the label next to the mainboard plug and one from the other plug that has 4 wires coming out(no clue what's it for lol)
      Hope this answers what you are asking,forgive me if it's not....
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        just seen BOTH pictures are up side down,call me a noob lol...I suggest turning your monitor around to avoid a stiff neck
          Please check pin 18, PS ON, before pressing power button and then after pressing it.
          Using multimeter, red probe on PS ON, black probe on chassis ground of TV, 20V DC range.
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            Will do !!!! Do I do this with plug to mainboard plugged in or un plugged?
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              looking at the plug,at the label side it shows 17 18....assuming that pin 17 is the one that has a bare metal pin coming out of the back of the connector going to the board and pin 18 being right below it(closest to the board)
              pin 17 shows 0 volts,then when striking the power on thing,it goes to 12 volts for about a second,then back to zero.
              pin 18 I couldn't reach,so I stripped the plug wire a bit and measured there..It's 0 volts and when striking the power on it goes to 0.79 volts for about a second,then back to zero....
              This I measured with the plug plugged in going to the main board...
                18 is on the lower row. It looks like the main board is sending the signal and the power supply is turning on, but there's a fault with the main board as it is turning off.
                In the fast track guide, try the "backlight on" hint.
                • martino
                  Not so "senior"
                  • Aug 2013
                  • 997
                  • canada
                  "fast track guide "backlight on"...I'm afraid I'm not following you????
                    This guide
                    Unplug CN201 to turn backlight on, page 2.
                    • martino
                      Not so "senior"
                      • Aug 2013
                      • 997
                      • canada
                      Ah..!! Thank you for the link...
                      I unplugged CN201 as described and the back light does not come on..
                      There is no "spy hole" in the back of the TV it seems,but if I look at the screen it stays completely dead...
                        What do you measure on pin 4 and pin 2 before and after pressing the button?
                        • martino
                          Not so "senior"
                          • Aug 2013
                          • 997
                          • canada
                          sry for the late responds,family stuff to be done...lol
                          But here it is...
                          pin 4: 0 volts on standby, 0.03v for halve sec when pressing the button.
                          pin 2: 0 volts on standby, 3.65v for halve a sec when pressed the button...
                            It looks like the main board is never turning the backlight on. Double check those readings, but if those are correct, the main board is likely the fault.
                            See here to try an EEPROM reset before ordering a new board.
                            http://wiki.samygo.tv/index.php5/UnB...EPROM_Location
                            • martino
                              Not so "senior"
                              • Aug 2013
                              • 997
                              • canada
                              Trying to locate the eeprom on my board with little success but will keep looking...might have to get magnifying glass as I must be getting older or parts are getting smaller,lol
                              Question about the backlight tho: Earlier I tried your suggestion on doing the backlight test thing,unplug cn201,plug tv in...That "forces" power supply to turn on backlight according to the chart... but it never turned on..!!!
                              Shouldn't that have turned on?? As the mainboard was not even involved in that test??
                                Hmm. What is the BN44 number of your power board? Service manual lists it as BN44-00357A, but it's got a mistake in the pin connector so I'm not sure if I can trust it.
                                • martino
                                  Not so "senior"
                                  • Aug 2013
                                  • 997
                                  • canada
                                  took a pic of the label,lots of numbers on there,hmmm not showing pic...hang on...
                                  • martino
                                    Not so "senior"
                                    • Aug 2013
                                    • 997
                                    • canada
                                    resized pic....lets try again....lol
                                      There should be a print with "BN44-12345A" on it (as an example) can you see any part with BN44- written on it.
                                      • martino
                                        Not so "senior"
                                        • Aug 2013
                                        • 997
                                        • canada
                                        it has a print on there saying :
                                        PD46AF0U-ZSM
                                        BN44-00352A
                                          09-07-2024, 05:50 AM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • marcinq
                                          Samsung UE60KS7000 No Standby Light
                                          by marcinq
                                          I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                                          I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                                          05-26-2025, 11:36 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • DXseekerMO
                                          Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                                          by DXseekerMO
                                          Hello everyone!
                                          Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                                          Symptoms:
                                          1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                                          2) TV does not appear to turn on
                                          3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                                          4) "Power on" terminal on Power Supply has 3.26v
                                          5) "A13V" terminals have 12.9v
                                          6) Stand-by test jumper on Power Supply has 12.9V
                                          7) Optical audio jack on Main Board illuminates
                                          8) With stand-by...
                                          06-09-2021, 12:19 AM
