Panasonic TC-50PU54 8 blinks picture flashes then dead
    Re: Panasonic TC-50PU54 8 blinks picture flashes then dead
    Also, did you use thermal paste and properly secure devices to the heatsink? My guess would be bad driver IC too.
    • atedesco
      • 3
      • usa
      #82
      Actual original resistor value per my Fluke is 6.1 ohm. A bit out of spec. from 5.6 ohm
      I did replace gate driver as a matter of course. Did not test original device.
      Yes, devices were secured to heatsink with thermal paste. Gate driver is SMD SOIC. I used my Hot Air Rework workstation to ensure ground pad was appropriately soldered to the board.
      The heatsink for the two devices was hot enough to sizzle the moisture on my finger. So devices were overdriven or heatsink is undersized.
      Not sure how to test driver chip.
      • tw2005
        • Oct 2011
        • 6457
        If a Fluke gave 6.1 and the tips and pads were clean , I'd consider replacing that resistor. My fluke (73) has a test lead resistance of 0.2 and those 5.6 resistors on a board I have(not the same board) read 5.7 and I've tried several .
        It's a metal film 5.6 OHM, 1/3W 5%. At 6.1 it's at 7.14%(depending on your leads) I'd find another 5.6 on that board or the SC and compare but it may be partially damaged and under use and heat the resistance may be unstable.
        • GTjacket
          Tried this repair with the kit, worked for an hour and fifteen minutes then died again. Has anyone bought the replacement board and had success? The kit didn't seem to do it for me.
          • carlsedillo
            • us
            #85
            I just did my panasonic TC-P50UT50 8 blinks problem.
            Ordered kit off ebay for $25.00 'Valley tv service' alumbra Ca.
            The ss board looked messed up from heat - all over.
            Started to remove components and messed up some of the circuit board. The solder was very hard to remove. The resistor is very hard to do since so tiny. I removed heat sink and transistor and diode first to get to smd resistor. Started last night took 5 hours - prayed a lot but watching NFL on it this morning. Beautiful picture. Thanks everyone.
            • dimafl666
              • 5
              I hope someone can help. My st50 had 8 blinks. First I replaced ss board, that didn't help, still 8 blinks. So I replaced A board next, blinks stopped, I get solid red light but no picture. Any ideas what's next? I saw on 7 blinks diagram that if no picture, replace su sd board. Is that what needs to be done or tv is no good no more?
              • tw2005
                • Oct 2011
                • 6457
                Exact model of TV and full view hi res photos of original A board and the new one so we can check if they are the same revision boards.
                Do you have a multimeter? Always a chance replacement SS board was dud. Where did you get that?
                • dimafl666
                  • 5
                  Exact model 55st50. When I replaced ss board in first place 8 blinks never stopped, so that's when I replaced A board. After I replaced A boarding was like, hmmm, what if replaced ss board was junk, so I went back to my original ss board. All same, no blinks now, just solid red light with no picture. Will make pictures tomorrow. Both of the replaced boards I got from eBay, different sellers, both claimed boards came from working tv
                  • tw2005
                    • Oct 2011
                    • 6457
                    the fact you now have a TV which sounds like it is not even trying to turn on or error blinks makes me think it's the wrong A board or may have another issue.
                    hard to say, really need to fault find it more, a multimeter may help.
                    A board needs to be marked as the picturem rev UB
                    the pink highlights shows ho to work it out. from shopjimmy site
                    • dimafl666
                      • 5
                      I feel really stupid, I disconnected a cable between ss and a board that's why it wasn't blinking. After reconnecting it and making sure everything is hooked up and all screws are tight, I still get 8 blinks.
                      • tw2005
                        • Oct 2011
                        • 6457
                        I don't know what to suggest except to get a multimeter and start checking the SS board for shorted transistors, possibly a DG302 I think is the one that commony fails. Are there any burn marks on the panel where the board mounts?
                        • tw2005
                          • Oct 2011
                          • 6457
                          I assume you have read the tech bulletin attached to post #78?
                          • ddpl
                            • Oct 2014
                            • 5
                            I was able to have the Resistor/Capacitor/Diode as mentioned by the technical bulletin replaced by someone, but I am still unable to get past the 8 blinking LEDs issue. I believe it may be the grounding pads as pictured below that may be at fault. What can I use to refill them in order for the board to maintain better contact?
                            Thanks.
                              Did you replace the FET/IGBT too? (other device on the heatsink)
                              • abdekader
                                • Jul 2014
                                • 73
                                • Turkey
                                #95
                                in power supply the red capacitor beside the 450 capacitor what's the value ?
                                Electronic Engineer from Syria,Aleppo
                                • ddpl
                                  • Oct 2014
                                  • 5
                                  Yes I do believe it was replaced (I wasn't the person who did the repair, but I do trust him).
                                  • ddpl
                                    • Oct 2014
                                    • 5
                                    Thanks.
                                    I've reuploaded the image for sake of clarity. What can I do the repair the sections marked by the red arrows?
                                    • tw2005
                                      • Oct 2011
                                      • 6457
                                      There's a possibilty the driver ic could be bad. have read someone reporting they had to replace it. The shopjimmy kit has all that plus the screws.
                                      that pad looks not too bad, maybe a light rub with fine emery to clean up , clean up the chassis too if burnt
                                      • Tuna Bait
                                        • Jun 2015
                                        • US
                                        #99
                                        Hey guys, First off thanks for all the great info on here. My TV went out couple days ago, my question. I live on the coast and there no tv repair places that can do this fix for me. I don't want to try to do the solder work as my skills only go as far as rc cars and wires ect ect. Is there a place a can get the ss board online and do the job myself without the repair kit? And is it worth it for me to try to do this myself? I cant seem to find any ss boards online. Thanks
                                        • tw2005
                                          • Oct 2011
                                          • 6457
                                          moduslinkpts do repair/return
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                            11-20-2024, 08:52 PM
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • FZG
                                            Panasonic AG-1000B VHS player with bad picture quality
                                            by FZG
                                            Hello!
                                            I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                            Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                            I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                            Also, what mechanism is this?
                                            Any feedback is appreciated!...
                                            05-06-2024, 07:16 AM
                                          • Bazfletch3
                                            Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                            by Bazfletch3
                                            Hi all
                                            While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                            I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                            From there I envisaged that the backlighting wasn't working, however...
                                            01-08-2024, 10:18 PM
                                          • kca
                                            Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                            by kca
                                            Hello all ~
                                            I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                            This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                            No picture. No sound.
                                            I tested all the voltages coming out of the power supply...
                                            10-12-2023, 05:23 PM
