Panasonic TC-50PU54 8 blinks picture flashes then dead
  • aasnowskate
    • 118
    • usa
    Re: Panasonic TC-50PU54 8 blinks picture flashes then dead
    I am still thinking A board. Do you have any more thoughts?
      I'm thinking A board, but I'm only about 80% sure.
      • aasnowskate
        • 118
        • usa
        thanks for all the help Tom. I ordered the A board for $18.99 on ebay. Hopefully that is what I need. I am at the limit of my knowledge, so it is worth the risk. I will notify this post when I get the board if it works or not.
          $19 is damn cheap for an A board!
          • tw2005
            • Oct 2011
            • 6458
            Hard to believe but probably this guy, has some real bargains at times. Must depend on the old supply and demand.
            Must have a few to clear and they'd be new sets transit damage too.
            http://www.ebay.com/itm/PANASONIC-TC...item27d633e3fb
            • aasnowskate
              • 118
              • usa
              #26
              Got the A board in today and still the same problem. the screen lights up and then goes into shut down with 8 blinks. Does anyone have any thoughts as to what I could look for at this point?
                I don't really know, can you try with your old SS board in case new one is bad? Very hard to tell without a scope to be sure.
                • aasnowskate
                  • 118
                  • usa
                  #28
                  Yeah, I tried the new A board with the original SS board. Same thing. Going off the service manual you posted earlier, I have a bad panel. I trouble shot the SD/SU board by following what was in that manual and it seems fine. This all was a result of a power surge. I guess it could have knocked the panel out. I was just hoping for something easier. I will just part out the rest of the boards.
                  • tw2005
                    • Oct 2011
                    • 6458
                    How long does the panel light up for? Is it a normal display or is it simply a quick flash and shutdown?
                      I really doubt a power surge can kill a panel. Bad electrode structure, due to dirt or debris, or broken ffc maybe, but not a power surge.
                      • aasnowskate
                        • 118
                        • usa
                        #31
                        The pic flashes on for less than a second and then goes into 8 flash mode. I didn't think a surge could cause a panel to go bad either, but I'm out of answers. I am still open to suggestions though.
                          You don't have a scope?
                          • aasnowskate
                            • 118
                            • usa
                            #33
                            No, I don't have a scope.
                            • aasnowskate
                              • 118
                              • usa
                              #34
                              According to the manual, the C3 board could also cause an 8 blink. It doesn't really say how to troubleshoot that board though.
                                Check the +3.3V and Vda on it. Vda should be around 55V.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  slide for what it's worth
                                  • aasnowskate
                                    • 118
                                    • usa
                                    #37
                                    I have 3.3 v on all three C boards when the Tv comes on and then they all go to 0v when it goes into shutdown and starts the 8 flashes. Where is the Vda?
                                      Do you see the little green SMD resistors? Vda can be tested on either end of those.
                                      • aasnowskate
                                        • 118
                                        • usa
                                        #39
                                        Thanks, I have 58 VDC when the tv starts up and it drops to 39 VDC when it goes into shutdown. That is on the C3 board
                                          Seems like there is no short there.
                                          8 blink panel failure is only caused by:
                                          - Shorted 3.3V/Vda on C board
                                          - Open SS FFC
                                          Neither of which you have determined to be bad.
                                          I really doubt it is the panel but I don't know what else to suggest, it is very hard to check these things without having a scope.
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                            11-20-2024, 08:52 PM
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • FZG
                                            Panasonic AG-1000B VHS player with bad picture quality
                                            by FZG
                                            Hello!
                                            I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                            Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                            I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                            Also, what mechanism is this?
                                            Any feedback is appreciated!...
                                            05-06-2024, 07:16 AM
                                          • Bazfletch3
                                            Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                            by Bazfletch3
                                            Hi all
                                            While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                            I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                            From there I envisaged that the backlighting wasn't working, however...
                                            01-08-2024, 10:18 PM
                                          • kca
                                            Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                            by kca
                                            Hello all ~
                                            I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                            This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                            No picture. No sound.
                                            I tested all the voltages coming out of the power supply...
                                            10-12-2023, 05:23 PM
