Philips 50PF7320A/37 Picture Problems
  • mxbraun
    • Aug 2013
    • US
    Hi folks.
    I've got a Philips 50PF7320A/37, from 2005, and about three weeks ago it started having problems. The bottom left-hand corner gets a bit of a "white out" condition, depending on what else is on the screen. The upper left-hand corner has a little bit of a blue glow to it as well.
    Pictures are here: http://imgur.com/a/KAdPt/noscript
    The bottom area of the screen also now seems prone to after-images for high-contrast or light areas. For example, my kids were watching a DVD of a teacher doing a math problem in front of a green chalkboard. The camera didn't move, which gave the words written in white chalk a few seconds to burn in. When the teacher (wearing a light blue denim shirt) moved in front of the the words, the words "shown through", him. In a minute or two, the words fade out (replaced by whatever other white stuff appeared on screen).
    The problem is not the inputs--it happens even when we go to the menu screen, which turns off all external inputs, and also when we view pictures via a USB flash drive plugged into the set.
    I pulled the set down, and (as advised on this forum and elsewhere) checked the voltages. Vs, Vsc, Ve, Vset, and Vsc_b were pretty much all on spec, or within .1 volts. Va was .5V off, but I adjusted it, and now it's on spec. None of the caps appear to be bulging or distorted.
    I suppose I could play around with those, but I'd rather know what I'm doing that blindly twist knobs, and break something.
    Any suggestions as to how to proceed?
    Thanks!
  • Rauni
    Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
    by Rauni
    Hello, this is my first post on this forum, and my first attempted to repair a TV.
    My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
    Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
    Read also that we should test what happens if we...
    10-01-2023, 12:06 AM
  • Schwoin
    Philips 243v5lhsb00 Monitor Picture too bright
    by Schwoin
    Hey everyone,
    the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
    While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
    you can see them on the top half of the photo.
    At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
    03-21-2023, 12:40 PM
  • madyoyo
    Philips 37pfl560: Yellow picture
    by madyoyo
    HI.
    I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
    Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
    05-30-2025, 10:16 AM
  • charlesdutcher
    No picture issue in Philips Chassis FTL2.1
    by charlesdutcher
    My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
    Is there someone having any symptom like this? How to fix it?
    Thanks in advance!​
    08-06-2024, 09:55 PM
  • groomit
    Philips 50PUS7363/12 Backlight but no picture
    by groomit
    I'm having trouble with above mentioned TV. Bought it defect.
    Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
    Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
    I can see backlight, but screen stays black.
    What I've tried:
    - Disconnect right side cable from T-Con -> same (backlight but no pic)
    - Disconnect left side...
    11-22-2024, 02:43 PM
