Samsung UN55D6450 turns itself off and on endlessly, no blinks
  • withalligators
    • Jun 2013
    • 267
    Re: Samsung UN55D6450 turns itself off and on endlessly, no blinks
    @ Johnboy1313 Yeah, if you decide to go into the panel and let me know how you did it, that would be awesome. I'm still very reticent to damage this thing accidentally. If it turns out I need them, I'd love to buy your backlight strips!
    @mmartell, thanks for that link, I'm going to go test them as soon as I can, I'll get back to you about the LVDS cable, but as far as I remember, you just squeezed the sides to release it.
    @splitcrete: I agree, I paid way too much, but it was bought from a friend who was sort of desperately down on his luck. I would never have bought it off craigslist for that much. It was more a little bit of charity in disguise.
    • johnboy1313
      • Nov 2012
      • 1959
      I was going to cut the tape with a razor. The screen is already fubar'd. If it helps any, I'll try to see if I can carefully peel the tape back to save the adhesive. Maybe it can be resealed.
      • withalligators
        • Jun 2013
        • 267
        @johnboy: That would be fantastically helpful!
        @mmartell: My LVDS connectors are much simpler than the one in your thread. It's 2 pushtabs on the side and that's it. Sorry.
        • mmartell
          • Oct 2013
          • 3189
          My lvds cable mystery is solved. There is a tab that must be flipped up first (exactly like the one's on the other side of the tcon) before you can squeeze and extract.
          • withalligators
            • Jun 2013
            • 267
            Good, luckily you didn't break it trying to figure it out. I've been there.
            I also tried to jump the LED backlights using the guide posted by Tom. I couldn't get anything to light at all, which worries me that it's not simply an LED strip failure. I suppose I could try replacing the power board first, but it's hard to get readings on this thing because it turns itself on and off all the time as soon as you plug it in.
            • mmartell
              • Oct 2013
              • 3189
              Ya small victory on the lvds cable, lol.
              Refresh my memory, does your PS cycle even with everything disconnected from it ?
              • withalligators
                • Jun 2013
                • 267
                no, with the main board unplugged, it doesn't cycle.
                • mmartell
                  • Oct 2013
                  • 3189
                  How about an audible "click" on power up ? I don't even see a relay on my PS and don't remember if it made any clicking sound when it was working properly.
                  • mmartell
                    • Oct 2013
                    • 3189
                    NM I see in your earlier posts you make reference to the clicks. AFAIK with these power supplies the relay should click when plugged in with no load. Mine does not. Hmmm..
                    • mmartell
                      • Oct 2013
                      • 3189
                      I just realized I haven't measured the voltages that lead to the led strips with the inference that if the voltages are there and there is no light then I myself will be looking at prying the panel apart to get to the strips.
                      I'm guessing you tried simply removing the PS <--> MAIN cable and pkugging the set in to see if that fires your backlight ? (If the .pdf didn't apply to you, too)
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Ones I had a similar issue. I have removed the PS_ON wire from it's connector and I have measured it and it was cycling. I ended up replacing the mainbord.
                        • withalligators
                          • Jun 2013
                          • 267
                          If I plug it in to AC with the power to main cable disconnected, there is a slight relay click. Then there is another about 5-10seconds after I unplug it. If I plug it in to AC with everything connected, the same relay click is audible, but then there is a much louder one everytime the backlights cycle on and off. Then, after I unplug it, there are continual relay clicks that lessen in intensity and increase in interval as the PS discharges over the course of maybe 20-30 seconds.
                          If I disconnect the main, the unit does nothing when I plug it in. I can get power throughout the board on different points, but I have no idea what I should be getting without the main connected. I do get the same readings across every transformer and cap on the inverter section of the board though, whatever that means.
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            withalligators and mmartell, I will be opening this set back up tonight and stripping it for parts. Let me know what measurements you need and I'll get the readings for you.
                            • mmartell
                              • Oct 2013
                              • 3189
                              I have the D6000 variant with a single 4-wire connector leading to the led's. I'm not sure how these are constructed so I wouldn't even know what measurements to ask for. But I am curious as to what this looks like inside
                              The four wires seem to be broken down into 2 pairs. One pair of wires measures a short. Not sure if that's normal or not.
                              • mmartell
                                • Oct 2013
                                • 3189
                                Oh and take pics !!!
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  I've got it on my "bench" dining room table right now. There is no careful removal of the tape. It is stuck down firmly. I had to slice the tape with a razor. Before I strip this. I'm going to see what can be done to reassemble it and power it on.
                                    6000 and 6450 should be similar in construction, maybe one has different smart features or main board.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      The tape surrounding the perimeter of the bezel needs to be peeled from all four sides to expose more screws.
                                      • withalligators
                                        • Jun 2013
                                        • 267
                                        Again, after you get it open, and I can repeat the process, I'd like the backlight strips from you. I don't know how else I'd ever get any, so getting them from you would be amazingly fortuitous.
                                        Edit: I typed this before a ton of replies but didn't press post. This is awesome! I'm glad there are some screws holding it together under that tape. So, the tape might be a little structural, but it's probably to prevent light leakage, eh?
                                        • johnboy1313
                                          • Nov 2012
                                          • 1959
                                          In some spots it's way easier to just remove the tape where it covers the screw head.
                                            09-07-2024, 05:50 AM
                                          • Egidio85
                                            Samsung UE55F8000SZ Turns on and off immediately
                                            by Egidio85
                                            good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                                            This defect happens continuously, hearing the classic click of the relay every time.
                                            Power supply board BN44-00636B
                                            disconnecting the mains and lamps from the power board always causes the same problem.
                                            Is it normal that without anything connected this power supply turns on and off cyclically?
                                            any suggestions on what to check?
                                            thanks in advance
                                            03-11-2025, 12:45 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
