Samsung UN55D6450 turns itself off and on endlessly, no blinks
  • withalligators
    • Jun 2013
    • 267
    That's the simple gist of it, my friend has a Sammy UN55D6450 that when plugged in turns itself on (relay clicks, backlight turns on) and then instantly shuts itself off. A few seconds later it repeats this process. He'll let me have it for 250. What do we think? Seems fixable. Main board? I haven't opened it or anything.
    Cheers,
    Alex
    Re: Samsung UN55D6450 turns itself off and on endlessly, no blinks
    I'd be thinking main board or t-con, is picture visible just as it cuts off? Could be shorted LED strip too.
    • withalligators
      • Jun 2013
      • 267
      It shuts off too quickly. Granted, I didn't have a video source hooked up, but sammys display a logo when they boot on, right? Anyway, this sounds fixable to me. Do you much smarter guys concur? I can pick up today or I have to wait a week.
      Cheers,
      Alex
      • capkid
        • Oct 2010
        • 1339
        It sounds fixable, and I'd be thinking main board, also. I'd probably buy it, although I'd have a hard time paying $250 (just my cheapness with regard to non-necessities ). It looks like a nice TV.
        LG Plasma Mal-Discharge Correction Service
        • withalligators
          • Jun 2013
          • 267
          OK guys, I brought it home. When you first plug it in, the relay clicks and it turns itself on, and a quick Samsung Smart TV logo appears for less then a second and then it shuts off. A few seconds later the relay clicks again and the screen flashes on and then off instantly, with no logo. The top of the screen is also brighter than the bottom as if that edge is lighting but the bottom isn't. Pressing the power button does nothing. It will continue this cycle until you unplug it. At which point the relay will click on and off a few more times, but at a progressively slower rate. Any new ideas? I'm still thinking main but wouldn't be surprised if it were a component on the power board. would photos of any of these boards help?
          Cheers,
          Alex
          • capkid
            • Oct 2010
            • 1339
            Yes, clear pics of the circuit board layout and what you see onscreen would be helpful.
            • johnboy1313
              • Nov 2012
              • 1959
              This is where I would start. Try unplugging the LED strips one at a time to see if it will stay on. If it shuts off, plug that one back in and unplug the next one.
              • withalligators
                • Jun 2013
                • 267
                The whole shebang:
                The main:
                The power board:
                TCON:
                • withalligators
                  • Jun 2013
                  • 267
                  How does one get at the LED strips? When the logo appears, it seems uniform. It's every flash after that where the backlighting seems uneven. Also, while the red LED seems to just turn off and on inverse to whether the screen is off or on, it blinks twice after each relay click after you unplug it.
                  • aaronwt6
                    • Apr 2013
                    • 855
                    • US
                    It apprears to me that there are tow cables at the top of the power supply going to the LED strips. I'd start by powering the set up with one then the other unplugged (ones at a time). If it powers up with either or unplugged then its going to be the LEDs.
                    • withalligators
                      • Jun 2013
                      • 267
                      I tried that, the relay clicked, but it wouldn't turn on with either unplugged
                      • withalligators
                        • Jun 2013
                        • 267
                        Yoicks, I can't find replacement main board for this anywhere except TVserviceparts, where they want 175. Anyone have any leads? It's p/n BN94-04359V. Shopjimmy lists these as substitute parts:
                        BN94-04357J
                        BN94-04359U
                        BN94-05038U
                        BN94-04359W
                        BN94-05038N
                        BN94-05038R
                        BN94-05038Y
                        • withalligators
                          • Jun 2013
                          • 267
                          Ok, I'm putting this on the backburner until I get a notification from ebay that one of these boards has become available. If it works, I'll update so there is a thread out there in case someone else encounters the same problem. If it doesn't, I'll go the TCON route.
                            You can also set a notifier up with ShopJimmy.
                            • capkid
                              • Oct 2010
                              • 1339
                              I also like to get main boards from Tristate Module, since they offer a 6-month warranty. I almost had to return a main board before I figured out that an obscure firmware update was necessary along with the main board replacement, and Tristate didn't hesitate to take back the board when I called them. So, I'd keep an eye out for an available board on their site.
                              • withalligators
                                • Jun 2013
                                • 267
                                Found a main for 80, disappointingly didn't do the trick. I looked more closely at the screen as it turned on and off, and the bottom edge LED lights may not be turning on. Is there a way to test this better?
                                Next time I go home, I'll take video in a dark room.
                                • withalligators
                                  • Jun 2013
                                  • 267
                                  Yeah, the bottom 1/4 or so of the screen is dark. It's *really* hard to tell in this video, but here it is:
                                  http://s294.photobucket.com/user/wit...07841.mp4.html
                                  Is there any way to test the pins to see if its actually the LED before I open up the panel?
                                  Thanks,
                                  Alex
                                    Any way you can get a full lit screen, maybe full white?
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      You cannot ohm an led strip. I'm learning about this more and more. The led tv incorporates a "balancer" to judge if the led strips are working optimal or not. What you need.ro do is get the service manual and find what voltages are on the balancer pins and led controller ic but im betting in you having some internal led error.
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        It may be a primary issue.
                                        ASRock B550 PG Velocita
                                        Ryzen 9 "Vermeer" 5900X
                                        Arc A770 16 GB
                                        eVGA Supernova G3 750W
                                        Alienware AW3423DWF OLED
                                          09-07-2024, 05:50 AM
                                        • Egidio85
                                          Samsung UE55F8000SZ Turns on and off immediately
                                          by Egidio85
                                          good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                                          This defect happens continuously, hearing the classic click of the relay every time.
                                          Power supply board BN44-00636B
                                          disconnecting the mains and lamps from the power board always causes the same problem.
                                          Is it normal that without anything connected this power supply turns on and off cyclically?
                                          any suggestions on what to check?
                                          thanks in advance
                                          03-11-2025, 12:45 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
