smd fuses on vizio e42vl
  • williamjf77
    • Jul 2013
    • 10
    • usa
    i blew a smd fuse on the 5v standby power going into my main board, does anyone know what the rating should be, or a part number? the only marking i can make out is 5A. thanks
    Re: smd fuses on vizio e42vl
    Will likely be 5 amp, 1206, 32V or higher, slow blow type, SMD.
    • williamjf77
      • Jul 2013
      • 10
      • usa
      thank you
      • gregory112
        Why put two fuses of the same rating in series? Or am I mistaken?
        by gregory112
        This Razer Blade 15 2022 motherboard does not have a schematic. Razer also does not give any schematics or boardviews. Around the GPU VRM circuits I found these two fuses rated for 1.5A (from the letter K).
        From the PCB trace I can see that the two are connected. These two are not connected directly to ground. I believe therefore they are placed in series. I wonder why is this? Also judging from the size of the PCB trace, this carries 19V power.
        Thank you in advance...
        03-18-2025, 12:46 PM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
      • mrtek
        Vizio M65-C1
        by mrtek
        Hi.
        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
        07-14-2025, 07:28 PM
