Why put two fuses of the same rating in series? Or am I mistaken?
This topic has been answered.
  • gregory112
    Programmer
    • Mar 2025
    • 6
    • Indonesia
    This Razer Blade 15 2022 motherboard does not have a schematic. Razer also does not give any schematics or boardviews. Around the GPU VRM circuits I found these two fuses rated for 1.5A (from the letter K).
    From the PCB trace I can see that the two are connected. These two are not connected directly to ground. I believe therefore they are placed in series. I wonder why is this? Also judging from the size of the PCB trace, this carries 19V power.
    Thank you in advance
  • Answer selected by gregory112 at 03-27-2025, 02:47 AM.
    mon2
    • 14666
    Most likely this is a multilayer PCB and this common junction is feeding a hidden power plane. Yes, replace the fuse and test again. Perhaps you are lucky and the fuse saved you from a disaster.
    • mon2
      • 14666
      No, trace each fuse back to a local ic. That IC is a regulator. So you are viewing 2 separate power rails and each has a protection fuse at the output and each output is tied together to drive a hefty current sucking load. Most likely these are multiphase power supply rails due to the high current demand by the load. Each rail will take turns turning on/off.
      • gregory112
        Programmer
        • Mar 2025
        • 6
        • Indonesia
        Thanks for the reply.
        So the fuses end connected to one with a PCB trace is the output right? I have a hard time understanding the trace as it does not lead anywhere, not even at the back of the board.
        The IC on the left as far as I know is MPS MP2940A VRM, and if I'm not mistaken, it is for the CPU. The top fuse seems to trace to the right side, the GPU circuits (judging by the number of VRAM chips around it).
        Nonetheless, the top fuse has blown. The big E7 capacitors near are not shorted. Because the PCB trace ends there without any connection to the back of the board, I am confused tracing it. I get that fuses don't get blown for no reason, well, I forgot to remove the battery and accidentally touched something with a screwdriver and I am trying to find if there are other shorted components near it. I am trying to find scenarios of what happened back then when I touched something and caused a spark, perhaps I touched something and it get shorted to ground, draws a lot of current, causing the fuse to blow. I intend to replace the fuse and try to plug it to power to test the voltage. Do you have any more ideas to test these?
        • mon2
          • 14666
          • gregory112
            Programmer
            • Mar 2025
            • 6
            • Indonesia
            Sure, I will replace it. I'll get back to it soon after I have done it.
            • gregory112
              Programmer
              • Mar 2025
              • 6
              • Indonesia
              Just want to update everyone on this forum just in case anyone is looking at this thread.
              Previously I thought because I sparked the motherboard with a screwdriver somewhere at the top, touching the heatsink, I suspect a huge current suddenly burst from the battery to the ground, killing one of the fuse. So far, I have only confirmed this fuse to be fauly, and other components nearby are normal (caps, ICs, and so on).
              I ended up just replacing the fuse and it works.
                Surface Mount Fuses Fundamentals Datasheet
                TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                10-07-2024, 06:07 AM
              • chth96
                Is it possible bridging tiny broken trace
                by chth96
                When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                cutting tiny trace.
                This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                12-03-2022, 11:32 PM
              • Sik_6ty_Sixx
                HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                by Sik_6ty_Sixx
                So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                02-18-2025, 05:06 AM
                Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                12-14-2023, 07:45 PM
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
