Samsung BN96-03775A Power Supply Problem
  • craigc15
    • 53
    Hi Folks,
    I've read through all of the threads associated with this power supply and none of them address my problem. I need help!!!!
    The TV sometimes works for hours, but other times it won't stay on at all.
    The voltage on the main cap (CP812) is only at 200 volts when the TV won't stay on. It's up around 370 volts when it works.
    I've changed just about everything, but it sounds more like a bad connection somewhere. I've scrutinized every inch of the board with a magnifying glass, but can't see any problems. I re-soldered most, if not all of the high-current connections, but no luck.
    PLEASE HELP ME!! I need to get this TV fixed and back to the customer.
    Re: Samsung BN96-03775A Power Supply Problem
    Are you sure about 200V? Not 160V? (which would be a lot more likely.)
    Before it fails, if possible, can you measure the voltage and see if it is dropping slowly, or does it drop immediately?
    Try heating up things and seeing if you can make the problem occur quicker, this may narrow down the fault location.
      Schematic of power supply if it's useful:
      • craigc15
        • 53
        I get 170 V in standby mode. I get it to stay on by reducing any output load, the easiest is to unplug the inverter plug, and that's when I get the 200 V. So maybe it's because it's operating at a lower output load.
        The voltages across the main cap are also all over the place. It is only steady in standby mode.
        I was watching the gate drive pin on the PFC MOSFET with my scope and the pulses were square when it was working, but more rounded when it wasn't.
        I suspect the problem is in the PFC circuit, but I've checked everything and the mosfet is being triggered and pulsing. It just must be not enough.
        I don't think it's heat-related because, as I mentioned, sometimes I will turn it on and it will work for hours just fine.
        I have the schematic. Thanks!
          by sam_sam_sam
          03-31-2024, 02:12 PM
          by sam_sam_sam
          07-01-2024, 06:34 AM
        • cheeky2
          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
          by cheeky2
          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
          06-15-2025, 05:12 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
