Sanyo 40" LCD TV 40xr11f blown power supply
  • mikoz
    A Tinkerer
    • Dec 2011
    • 39
    Gday,
    Was handed this LCD after the guy tried fixing it himself. Symptoms started with a buzzing DPDT switch, sometimes would start up fine other times the red led would flash and not come out of standby. The owner decided to replace the DPST switch with a SPST switch by twisting the same coloured wires together and POP goes the TV. Long story short, the psu now has burnt traces between the plug socket and the switch socket (which I have soldered in wires between). I do not want to do further damage to this board by powering it up but the fuse tests good still.
    How would one start testing this board before applying power to it?
    PSU model is 8KI0132010 A1 1141
    Cheers
    Mick
    Re: Sanyo 40" LCD TV 40xr11f blown power supply
    Pictures?
    • mikoz
      A Tinkerer
      • Dec 2011
      • 39
      Sorry about that, will get some pics up this morning.
      • mikoz
        A Tinkerer
        • Dec 2011
        • 39
        Heres some pics, dodgy solder I know...
        • mikoz
          A Tinkerer
          • Dec 2011
          • 39
          Update:
          TV now working, Replaced dp switch and wiring to psu (high resistance), 3 x 16v 1000uf caps on standby circuit & the red 5a radial fuse and voila job done.
          Mick
          • tw2005
            • Oct 2011
            • 6458
            Just picked up same model. symptom described was would not turn on, flickering standby LED. Got it home and dead as, no standby LED. Did not bother checking voltage, grabbed a hair dryer and warmed everything up and eventually standby came back, could not turn on,more heat, turn on via side panel - no remote operation and eventually everything now works.
            so definitely bad dried out caps I'd say, just not sure if only on the PSU but I think a full recap of the unknown crap branded caps is a good path to take.
            can't get it to fault again, see what happens overnight leaving it off.
            • tw2005
              • Oct 2011
              • 6458
              LCD-40XR11F
              Did not fault left off overnight, recapped the PSU and not super confident if that's good enough. The main feeds the IR board which has the standby LED. probably would have been smarter to measure things whilst it was faulted.
              There's no 1000uf 16v caps i could find that the OP states.
              Could not get any hits for the samsung panel LTA400HM09 or LJ96-05566C. TCON is integrated, PSU heatsinks and entiire LCD chassis get quite warm(hot).
              There's a hotspot 1/3 from the bottom right across the rear so hot a few seconds is uncomfortable. is the norm?
              last pics are of panel failure from the websearches.
              I thought the big plus with LCD was less power and heat
              Australian NZ models
              http://cncms.com.au/index.php/sanyo-service-manuals
              • tw2005
                • Oct 2011
                • 6458
                I have a suspicion the OP is talking about 100uf 16v surface can caps on the main
                • cheeky2
                  Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                  by cheeky2
                  This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                  I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                  Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                  06-15-2025, 05:12 AM
                • cmlewis89
                  LG 47LB5DF blown power supply board
                  by cmlewis89
                  Hi folks,
                  I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                  09-03-2024, 07:50 PM
                • shovenose
                  Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
                  by shovenose
                  Got this one for free because, well, it no worky.
                  A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
                  Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
                  08-11-2021, 01:26 PM
                  Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                  This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-06-2024, 05:30 AM
