Toshiba 42hl196 no power no led flash
  • notallbad
    • Oct 2012
    • 1190
    Re: Toshiba 42hl196 no power no led flash
    Is it a 2 or 3 pin diode?
    Part number of the diode, should be visible.
    • audiofreak19
      • Apr 2013
      • 556
      • usa
      It's a 2 pin diode. I looked it up and it was called a rectifier diode.
      • audiofreak19
        • Apr 2013
        • 556
        • usa
        Anyone got any ideas
          Part # of diode?
          • audiofreak19
            • Apr 2013
            • 556
            • usa
            Fmc26u and fmxg16
            • audiofreak19
              • Apr 2013
              • 556
              • usa
              #26
              I'm reading the schematic from the service manual and its giving me a headache. I don't know why q880 is over heating. I'm trying to test the diodes around it and one way they are reading .661 and the other way they read 1.394. On all the diodes I have tested so far.
              • audiofreak19
                • Apr 2013
                • 556
                • usa
                #27
                I'm thinking its something with the sciene board cause othe people had the same problem with the back light turning on for a couple seconds and then turning off and repeating.
                • audiofreak19
                  • Apr 2013
                  • 556
                  • usa
                  #28
                  So I realize now that when I plug the tv in the 3 red lights flash and then after 5 sec or so the tv tries to turn on. Do u think it could be from a messed up solder joint from when I did the 3 ic replacement.
                  • PantherDave
                    by PantherDave
                    Hi all!
                    I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • Mark01
                    Dell Optiplex 7490 AIO - red power led after flash
                    by Mark01
                    Hi guys,
                    This is my first post! ๐Ÿš€
                    I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
                    Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                    07-04-2025, 12:54 PM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
