tc-p50S2 10 blink SC troubleshooting
  • carpetweb
    replied
    Re: tc-p50S2 10 blink SC troubleshooting
    I had an sc board blow on my tcp50g25 13 months ago and replaced it with a new board...now 13 months later it blew again....I'm thinking its not worth the headache to find another board and repair it again. Will NEVER EVER buy panasonic again.
  • allenrw
    replied
    Here is the latest update, I started pricing parts and because they came from different sources including used Panasonic boards the price rose quite quickly and there was no certainty that I had found all the bad components.
    I sat back and watched Ebay.
    Don't you know it a week ago someone posted a SC, SU, SD board set as a new pull for $117 US delivered.
    It works fine so far but I think there may be a clue as to why these boards go bad, some of the heat sinks get a bit warm so I am considering a couple of low noise fans mounted externally.
    Thanks for the help TW2005, you made this a lot easier but it was still very time consuming, a great learning process.
    My advice for a repair like this is to take the time to check the TV carefully at the component level looking for shorted components and missing voltages to determine which boards are bad (the blink codes were a bit misleading), then if it is a couple bad components that can be had for reasonable money fix it up, but if it turns out that there are many components then it is probably better to get a warranted used board.
    The trick here I think is to take the time to verify that you find all the problems so you don't end up buying parts or boards and then have to buy more boards or damage your new boards because you missed something.
    Once I discovered that there was a short in the SC board I disconnected it and checked the voltages on the P and A boards pretty carefully especially those related to the SC board.
    It has been an adventure!
  • tw2005
    replied
    Originally posted by glen65
    Yes
    None of them are shorted, but not really a guarantee they are good.
    I am assuming you are talking in respect to the circuit ground. If so
    the yes I did. The resistance measured up into the kilo-ohms, on both
    the 5 and 15 volt lines.
    k ohms sounds like it could be ok, fet drivers usually go open on the output and or short or low ohms on the Vcc which i believe is the 15V in from the few I've played with but not your model
  • glen65
    replied
    Originally posted by tw2005
    Ok, well hope it works out. By all i assume all the SMD stuff as well,
    Yes
    the voltage regulators and possibly failed inverter ICs,
    did you measure the resistance for the P5V and P15V lines in.
  • tw2005
    replied
    Ok, well hope it works out. By all i assume all the SMD stuff as well, the voltage regulators and possibly failed inverter ICs, did you measure the resistance for the P5V and P15V lines in.
  • glen65
    replied
    UTSOURCE ,would have them and possibly Ebay.
    DG502LW should sub ok for the 2PG011, AFAIK that one superceeded it.
    RJP6065, i suspect RJP63F3 would do there
    At a couple of bucks each from UT, I'd take a chance but I do not recommend purely replacing the IGBTs that are shorted and expecting it to then work.
    odds are they will simply blow again.
    I wouldn't either,
    That's why I checked all other components such as transistors, diodes resistors, ect.
    Also checked the FET output pins of the M81707FP ICs for shorts. The SD and SU boards
    can be had pretty cheap, and might change them for good measure.
  • tw2005
    replied
  • glen65
    replied
    I've had no quality issues although sometimes the leads look a little suspect like it could be fake but touch wood every part I've received has worked and tested similar to what they should be.
    Some arrive with pre bent leads which are sometimes in the wrong direction needing careful rebending to install them . Mainly the panasonic IGBTs. Some have a R stamped and they are always bent in the opposite direction to the non R. originally i thought it was an electrical difference but now I think it simply means the leads are pre-bent in the reverse direction as part of the factory process.
    I have no evidience to back the theory but no issues.
    delivery is slow unless you shell out for DHL etc which adds a good chunk of $$ but if the order was large enough may work cheaper but a good 3 weeks from china to Aust, maybe 4. No idea how transit is to the US, would not surprise me if it was quicker.
    They can take a while to compile the order but always well packed and static protected.
    i'm confident if you did get fakes they'd sort it out, I expect their intention is to supply good parts but I'm sure they get caught themselves.
    hope this helps.
    Thanks for the reply,
    I asked because I am currently working with a TNPA4844AD SC board
    with the following shorted components. 2PG011, RJP4585, RJP6065.
    These are obsolete numbers, and I cant seem to find anything to sub these IGBTs.
    The sticking point is the current spec. The 2PG011 for example, has a continuous current rating
    of 40 amps, (not too much problem there), BUT at the same time it has a
    pulse current rating into the 200 amp range. The highest I could find was
    about 160. If I cant bring myself to buy the HK semis, I'll just have to bite
    the bullet and pay the higher cost from Panasonic.
  • tw2005
    replied
    I've looked at UTSOURCE a few times but am concerned about quality.
    You seem to have experience with them, have you ever had any trouble
    in that department? Also (generally) how long does it take them to ship
    an order? Thanks.
    hope this helps.
  • glen65
    replied
    post 7 & 14 is all the info and suggestions I can give you.
    UTSOURCE i got the bulk from there, there are subs for some of those common parts like the Toshiba logic chips ( eg TI) , voltage regs, signal transistors.
    I highlighted parts you could strip from a cheap SS board.
    Ebay and local suppliers. RS components here have free post for online purchases for Australia, maybe you have a similar supplier with same deal?
    UTSOURCE has a minimum unit cost of $1 so some of those bits are like 20-50c parts.
    They also tend to make the prices up sometimes, not unusual to get quoted more than their Ebay listing but I have also been quoted less too.
    You will be waiting a while with the $4 post from china.
    That's just the way it is.
    an order? Thanks.
  • tw2005
    replied
  • allenrw
    replied
    So the price and availability of parts is now the problem.
    I am having trouble finding all of them and the ones I have found are from different vendors so there are shipping costs added.
    A used guaranteed board is about 120 dollars US and SU/SU boards are 12-20 dollars US.
    The tv costs 500 dollars US new.
    Bottom line is I need a cheaper source for the parts.
    Any ideas?
  • tw2005
    replied
    Originally posted by allenrw
    The boards were out on the bench connected to the meter only and disconnected from each other.
    I tried changing leads some and I don't think the results varied.
    Best get fresh ones then, I could'nt think of anything worse if we get that SC going only to kill it with the buffers.
    At least you can run that SC up with the bypass in the meantime without them.
  • allenrw
    replied
  • tw2005
    replied
    Attached are the buffer board measurements
    yeah, I'm a little baffled by those. Vscn_F is spot on.
    But the others don't match but they all read the same on both boards.
    from the few boards I've had a chance to test, at least something generally shows short.
    When I tested mine they were removed from the TV. i don't think having them hooked to the panel would matter but a couple of questions.
    1 Were they disconnected from the 3 SC connectors/
    2. earth screws removed?
    3. interconnecting ribbon disconnected between SD & SU boards?
    4. try again and reverse the probe polarity and recheck results?
    Two figures i could get consistantly were Vfo 1.8Mohms and Vsc_F at 220kohms.
    I just found some more results from my brothers TV and that had bad SD,SU,SC.
    On that one I have 500-600K on 5V_F on the SD board, 2.3Mohm on SU but both had shorted Vfo (1.8M normally) Vscn_F on both of those dead short.
    if you can't get 1.8M or so on the Vfo and 5V_F is still only 100'sKohms then yeah I tend to agree there's enough difference to bail out and find some good ones.
    With my brother's TV buffers as they were I got lazy and did not test them assuming they were going to be good like mine.
    End result was blowing up a brand new SC.
  • allenrw
    replied
  • allenrw
    replied
    I'll post the buffer board info tomorrow I hope.
  • tw2005
    replied
    Re: TC-P50S2 10 blink SC troubleshooting,TNPA5105 repair
    Q16401 DG3D5020CSLW TRANSISTOR 1 DG502LW shorted
    Q16402 DG3D5020CSLW TRANSISTOR 1 DG502LW shorted
    Q16421 B1JAEP000014 TRANSISTOR 1 RJP43F4A shorted
    Q16422 B1JAEP000014 TRANSISTOR 1 RJP43F4A shorted
    Q16521 B1HFPFA00001 TRANSISTOR CPH5524-TL-E not sure if it was shorted but will replace anyhow ((Pins 2-3 & 1-5 , 2-3Mohms from memory(I'm not shouting))
    IC16521 C0ZBZ0001708 IC M81737FP again not sure if it was shorted but will replace anyhow (Good idea, did you check the Vcc-gnd resistance, how did P15V resistance right after this was removed? If still funny,NAND GATE cct, IC16691,Q16647 last board both those were failed)
    Q16661 B1JAER000010 TRANSISTOR 1 RJP63F3A shorted(every board this was failed)
    IC16771 C0CBADC00072 IC 1 78L05L, TA78L05F shorted(shorted out of cct too? 1 of 3 boards this was bad)
    Q16701 B1ADCN000007 TRANSISTOR 1 MMBTA92 shorted
    Q16702 B1ABCF000231 TRANSISTOR 1 2PD601ART,215, 2SD0601A0L shorted(every board this was failed)
    IC16773 C0JBAB000715 IC 1 Toshiba TC7SH14F shorted(every board this was failed)
    C16708 F1H1H104A970 C 0.1UF, K, 50V, lost during testing, gawd these things are small and hard to hold!
    IC16501 C0ZBZ0001708 IC M81737FP not sure if it was shorted but will replace anyhow
    IC16661 C0BBBA000024 NJM2903V(TE1) , removing this cleared a ~500ohm path 16V_F to VAD (very surprised to see this on the list, no problems on mine but did remove and compare to a known good one, wish I had not with the soldering)
    R16900 D0GB103JA057 M 10K OHM J 1/10W , tested 3.9k in circuit supposed to be 10k(so out of cct it was? It all ties in cct ,part of which heads down to shorted Q701,702,IC773 so that may be the real issue?)
    Green part numbers are also on that SS board I mentioned for scavanging.
    M81737FP Qty 1
    NJM2903 Qty 1
    CPH5524 qty 5
    F1H1H104A970 0.1UF, Qty 3
    D0GB103JA057, M 10K OHM J 1/10W Qty 3
    My very first repaired board, my post #22 is very close to the fault profile of your board.
  • tw2005
    replied
    Do me a favour and list what you did get on the buffer boards for resistance.
  • allenrw
    replied
    To recap
    Q16401 shorted
    Q16402 shorted
    Q16421 shorted
    Q16422 shorted
    Q16521 not sure if it was shorted but will replace anyhow
    IC16521 again not sure if it was shorted but will replace anyhow
    Q16661 shorted
    IC16771 shorted
    Q16701 shorted
    IC16773 shorted
    IC16501 not sure if it was shorted but will replace anyhow
    Q16702 shorted
    IC16661 removing this cleared a ~500ohm path 16V_F to VAD
    C16708 lost during testing, gawd these things are small and hard to hold!
    R16900 tested 3.9k in circuit supposed to be 10k
    I test a number of capacitors that had 200 to 500 mF in circuit and were correct out of circuit. I started not pulling these caps if they weren't shorted, I didn't find a single shorted cap.
    I ohms, diode or capacitance tested every device that was connected to the bad parts and found nothing else.
    I used TW2005's SU and SD readings for his cards (different from mine some) and found enough differences to make me consider getting new/used ones (they are pretty cheap).
    So I will most likely order all these parts and see if it goes.
    I have considered applying, with current monitoring/limiting, 15 and 5 volts to SC20 and see what happens before giving it an installed full power test.
    The question that still remains is what caused all this? I haven't had time to see what the common thread may be.
    Anyhow the beat goes on, stayed tuned for the continuing saga.
    TW2005 thanks again for your input, I probably wouldn't have gone this far without the direction you provided.
  • janos666
    Pioneer LX5090 - 2x Red blink after auto-shutdown
    by janos666
    I was trying to reset the Pulse Meter and re-adjust the Panel-1/2 settings in the SM on an exceptionally old Pioneer LX5090 (51k power-on hours according to it's SM). I did this many times on much less aged specimens (with 10-20k hours) without issues. After following the usual workflow, I noticed the darkest gray shade showed up black with bright sparkles. I tried to adjust some other parameters but it didn't disappear. Then I went on and restored the old values of the parameters I don't usually touch (although I did this from memory, so I might have made an error). After that, I started going...
    03-26-2023, 11:20 AM
  • EazyBone
    Un50cu7000 2 blink oddity *partially solved
    by EazyBone
    I write this to maybe help another with this TV.
    So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
    The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
    03-18-2024, 10:24 PM
  • kacangpolo
    Asus X415EA Auto start when shutdown ( Laptop cannot shutdown with baterai only )
    by kacangpolo
    I have problem with my laptop, with code board X415EA 2.0,
    laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
    I did :
    1. Flash Bios
    2. RTC_RST 3.3V
    3. LID_SW 3.3V
    4. WLAN_WAKE# 3.3V
    08-26-2025, 04:42 AM
  • Vebririon
    panasonic TX-P50V10E 6 blink led problem
    by Vebririon
    I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
    Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
    I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
    05-17-2025, 10:16 AM
  • cruiser_
    A1466 820-00165 intermittent shutdown
    by cruiser_
    hi there,
    Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
    Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
    Gives shutdown cause -128.
    Seem to work fine in SMC bypass.
    Same shutdown happens with disconnected TP/KB/KBLED/CAM.
    Observations:
    - SMC_RESET_L - when pulled down - plug goes orange/green and...
    10-11-2022, 12:06 PM
