Samsung LE40A456C2D
  • AndyLea
    • Mar 2013
    • 14
    • Uk
    Samsung LE40A456C2D
    Hi picked up a Samsung 40 inch LCD TV.
    When i first got it , it had a blown power board fuse
    and swollen caps. I replaced 4 caps and the fuse
    and re-inserted the board. The fuse then literally vapourised with a bang.
    I then removed that board as it must have a nasty short.
    Anyhow, ordered another psu off ebay and got it going again.
    Checked voltages too, all seem ok.
    Latest aggrovation is the TV does not show any picture
    when an HDMI source is input, but DOES work ok with
    a SCART input, both video and audio.
    Have tried a few service menu factory resets but made no difference.
    Questions are : A) Is there any easy checks i can do,
    im a complete novice but want to learn.
    B) Is this an AV board problem ?
    C) Can i eliminate the t-con board.
    D) Could the blowing first power board screwed up the av board ?
    PS Have a LG tv almost exhibiting the same problem, sound through Scart only and nothing through any others inputs. Must be something common here.
    Any ideas guys ???
    Andy
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • ohren
    Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
    by ohren
    I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
    I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
    The models launched in 2018 and 2019 respectively....
    09-08-2023, 05:24 PM
  • C152Heavy
    Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
    by C152Heavy
    Summary for TL-DR readers:
    • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
    • Have obtained Samsung schematic & service documents - Can upload if helpful.
    • Have read ALL applicable threads
    • C1818 and CP820 replaced as low hanging fruit
    • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
    • VCC pin (18) of PFC...
    01-11-2023, 02:53 PM
    09-07-2024, 05:50 AM
