Samsung LN40B630N1F PSU Problem
  • landyboy
    • Apr 2013
    • 443
    I just picked up a Samsung LN40B630N1F that will not power up no lights on the front at all. When I opened it I found the fuse noted below in the picture blown. I replaced the fuse and as soon as I put AC power to the board the fuse blew again. I thin pulled the board out of the inverter sockets and disconnected it from the main board put AC to it and the fuse blew again. With the fuse removed I have around 160vdc volts across the fuse sockets and about 33vdc to ground both sides.
    Re: Samsung LN40B630N1F PSU Problem
    Schematic
    http://www.tgohome.com/ServiceManual...&Search=Submit
    Test bridge, diodes, fets, etc.
    • landyboy
      • Apr 2013
      • 443
      QI820
      50 ohms 50 ohms .3 ohms
      QI821
      39 39 .3
        It's dead, Jim... You'll likely have to replace a few resistors and diodes around them, but it's transformer isolated so the controller IC should be OK.
        • landyboy
          • Apr 2013
          • 443
          I also tested the Bridge Rectifier
          neg lead to pos lug pos lead to ac lugs 1600ohms
          same with pos lead on neg lug and neg lead to ac
          • landyboy
            • Apr 2013
            • 443
            What readings should I see on those two?
              Expected for FET: Open all directions except 2-3 or 2-1 where one diode may be visible in reverse.
              Test bridge out of circuit to check it.
              • landyboy
                • Apr 2013
                • 443
                I found these do you think they are acceptable?
                FDPF 7N50 ( 7 AMP) MOSFET UPGRADE FOR FDPF 7N50U (5AMP) MOSFET
                  Should be OK.
                  • landyboy
                    • Apr 2013
                    • 443
                    UPDATE: Replace the two above mentioned FETS and set is working great!!
                      Nice one! Thanks for feedback.
                      • ajimetro
                        • Aug 2013
                        • 6
                        • Colombo
                        I had same kind of issue in Toshiba 40AV700E LCD TV.Two FETs are burnt (7N50U) & i could find the FET of 7N50 (not the 7N50U) in my country.So I replaced the two FET s & also Smoothing cap 1000uF/10V are Leak.Then replaced it also
                        & power up the TV Using 100W bulb replaced with main Fuse.
                        Its blinks with bright.Then i replaced the fuse & power up.It works for about 30 seconds & burnt the FETs again.Not only that near SMD resistors & Diode are also burnt.Now I couldnt find the values for SMD s.So how may I find the values for that & may i replace the 7N50U with 7N50?
                        Thanks.
                        • DV442
                          • May 2014
                          What should the readings be at Q1820 and Q1821?
                            Nearly open circuit all but one way around.
                            • DV442
                              • May 2014
                              Hmm, thanks for the info.
                              It appears that Q1821 is good. But on Q1820 I have readings that are not the same.
                              Q1821
                              Pin 1 - Pin 2= .4 ohms
                              Pin 1 - Pin 3= 1.0 ohms
                              Pin 2 - Pin 3= 1.1 ohms
                              Q1820
                              Pin 1 - Pin 2= .3 ohms
                              Pin 1 - Pin 3= 32.3 ohms
                              Pin 2 - Pin 3= 32.3 ohms
                              Would you say that Q1820 is bad? Thanks for your help!
                              • rawilson3
                                Idea Pimp
                                • Jul 2014
                                • 12
                                I am having the exact same issue and the same fuse is blown. Is there a diagram that shows the components tested and expected test values that I could follow to diagnose and repair my set? Thanks for your time and help.
                                It does not take all kinds, but you get them.
                                  Is your board # is BN44-00264A? If it is then take the resistance readings as shown in post 3~10 and report the readings.
                                  • rawilson3
                                    Idea Pimp
                                    • Jul 2014
                                    • 12
                                    Thanks for the reply. I will double check the model of the board and test if applicable tonight and followup with results.
                                    Thanks!
                                    • rawilson3
                                      Idea Pimp
                                      • Jul 2014
                                      • 12
                                      ok
                                      Q1820
                                      1-2 : 2.6
                                      2-3: 2.0
                                      1-3: 2.6
                                      Q1821
                                      1-2: 1.9
                                      2-3: 1.9
                                      1-3: 2.6
                                      • rawilson3
                                        Idea Pimp
                                        • Jul 2014
                                        • 12
                                        Any ideas if my parts are dead? Should I take any additional readings?
                                        Thanks!
                                          09-07-2024, 05:50 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • alro7779
                                          Samsung UN55MU6103F video problem; has colored stripes on the display
                                          by alro7779
                                          Hello, everyone!
                                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                          09-27-2025, 11:29 PM
                                          09-06-2024, 11:40 PM
