Samsung LN46A650A1FXZA
  • splitcrete
    • Dec 2012
    • 387
    • usa
    Re: Samsung LN46A650A1FXZA
    Are the chassis pictures ok Tom ?
    • splitcrete
      • Dec 2012
      • 387
      • usa
      I thought a buck converter was like 90-95 % efficient . Where is all that heat coming from? Could it be a bad winding in the housing of the inductor ? the other buck converter run about 50 deg. cooler .
        Around 85% is possible, 90% is really good, 95% not really possible except with very good converters.
        If the processor draws around 10W which is typical with modern video processors then you'd be losing around 1.5W which produces a fair bit of heat in the inductor and MOSFET, especially with no heatsink.
        Have you tried freeze-spraying parts to make it go wrong quicker (or see if that makes it work?) Or hairdryer to heat stuff up?
        • splitcrete
          • Dec 2012
          • 387
          • usa
          I used a hair dryer last night and it trips at about 200 deg. and the power goes off. sprayed freeze spray on it and it started up by it self
            Can you try the heatsinked processor instead? It is possible the inductor has an intermittent contact, but unlikely. Try measuring voltage on both ends when set not working.
            • splitcrete
              • Dec 2012
              • 387
              • usa
              #26
              I know it was 200 because I used my laser thermometer to check.
              The volts were .0 on both sides in standby mode.
              • splitcrete
                • Dec 2012
                • 387
                • usa
                #27
                .0 volts both sides
                • splitcrete
                  • Dec 2012
                  • 387
                  • usa
                  #28
                  How about if I swap out the inductor,and if its gets the same conditions I can swap it back. just to prove that its not a bad inductor ?
                    You can do that, but I'm not sure what the ratings of that inductor will be.
                    • splitcrete
                      • Dec 2012
                      • 387
                      • usa
                      #30
                      I have one same rating from from a different make board. The set is running well with my little fan running. Think I'll leave the fan in when I find the problem. So many of these lcd samsungs are having the same issues. The strange thing my relay never did the clicking thing, even before I changed the caps.
                      Are the pictures ok?
                        Your pictures are fine,
                        You will quickly learn from this forum that Samsung TVs are poorly built. And ideally, they are to be avoided in future purchases.
                        • splitcrete
                          • Dec 2012
                          • 387
                          • usa
                          #32
                          I grab what I can get, people want crazy money for non working tvs.
                          The most I will pay is a dollar an inch.
                            Around here I pay £1/inch typically so around $1.60/inch.
                            • splitcrete
                              • Dec 2012
                              • 387
                              • usa
                              #34
                              Tomorrow its going to be 95 deg. turn off a.c. and run it with the cover on so it can build up heat in the cabinet. If it doesn't turn off I am going to leave my little fan in and running. If it turns off I will be back. Thank You for the support on my little project.
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • ohren
                                Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                by ohren
                                I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                The models launched in 2018 and 2019 respectively....
                                09-08-2023, 05:24 PM
                              • C152Heavy
                                Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                by C152Heavy
                                Summary for TL-DR readers:
                                • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                • Have read ALL applicable threads
                                • C1818 and CP820 replaced as low hanging fruit
                                • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                • VCC pin (18) of PFC...
                                01-11-2023, 02:53 PM
                                09-07-2024, 05:50 AM
