PANASONIC plasma TH-P42X20A, SOS4,1,10,6,8
  • flocko
    • Nov 2012
    • 1121
    • uk
    #41
    Re: PANASONIC plasma TH-P42X20A, SOS4,1,10,6,8
    Thanks Tom Will a DG502 be Ok in place of the DG501 as i am out of 501s but can get my hands on DG502? when i these faulty parts are replaced and with the SS board out will the green LED light up on the SN to show if its working
    • tw2005
      • Oct 2011
      • 6458
      have you read post #31? The LED will light for as long as it takes for the SOS to trigger which is pretty much straight away. This bad SN I have it lights momentarily, not full brightness.
      Not sure how much of a guide that will be for you.
      Also, this cct design and parts, are very close to the 5081. With Q661 shorted I'd be wary of IC773. What do you get in diode pins 3 - 4 ?
      Got any ymain from Samsung 42C450 series? RJP63F3 on them.
      • flocko
        • Nov 2012
        • 1121
        • uk
        #43
        i have the RJP63F as these are used in lots, am out of DG501s can get 502s?With regards IC733 in diode mode com to Pin 3 - Pin 4 shows .146,com to pin 4 - Pin 3 shows .234 ? but thats with the shorted Q661 still in the board
        • tw2005
          • Oct 2011
          • 6458
          On the dead board I'm getting short(.07), on working board 0.6 and .9 charging to a bit over 1.0.
          My Q661 was short all 3 legs.
          • flocko
            • Nov 2012
            • 1121
            • uk
            #45
            i dont know what that is telling us but will retest when i replace Q661,you used a DG502 for the 501 i will do the same as i have no 501s if it worked for you should be Ok,i will try to get the parts changed tomorrow and let you know if it changes the readings on IC733, i have a new RFU20 to replace D461 and new JRP63f for Q661
            • flocko
              • Nov 2012
              • 1121
              • uk
              #46
              well here is were i am at replaced D481(RFU20) +Q661(RJP63F) and removed and tested Q451(DG502)the short is not on the component but shows across the collector - emitier pad on the board so have left replacing this for now but have not returned it to the board, i rechecked in diode mode IC733 and still showing the .146/.238 it was before the replacement of Q661, the thing is now is there allways this short across Q451 or is something else short ( diode) ?
              • flocko
                • Nov 2012
                • 1121
                • uk
                #47
                Did not have to look to far D451 goes across C-E on Q451 and it reads short both ways just need to find a replacement
                • tw2005
                  • Oct 2011
                  • 6458
                  That could be handy info if i try repairing this. It was going to be a toss up on whether to start at the Transistor or diode. i have found though generally when those IGBTs fail, they're shorted on all three legs.
                  Got any scrap boards to scavange?
                  D1FK60-5073
                  • flocko
                    • Nov 2012
                    • 1121
                    • uk
                    #49
                    yes i will find S/fast recovery diode off something( 600v 1 Amp) have a lot of old LG Sus boards sure to have them on,will leave it till my IGBTs get here for the SS board, what do you make of the readings on IC773? Thanks again for your input Flocko
                    • tw2005
                      • Oct 2011
                      • 6458
                      I trust your meter is of reasonable quality so it's off compared to my working board.
                      A shorted Q661 points me to the inverter cct and i'd take my time being real careful looking for shorted transistors and Q818 did not go short but was faulty on the 5081.
                      I'd be suspicious of Q818, 2SK3018 but a 2N7002 will also work. Package size is a pain though, smaller than the others.
                      • flocko
                        • Nov 2012
                        • 1121
                        • uk
                        #51
                        I see in the States some one on Ebay has repair kits for the TNPA 5066 and TNPA 5072 does not list all part but for the SN Q401/Q402/Q421/Q661 IC7xx/,transistors and diode 9 parts in total, and for the SS just 5 parts, they say will fix 90% of faults
                        • tw2005
                          • Oct 2011
                          • 6458
                          I see a SS/SN for sale on Ebay UK 50 quid. Was 65 but from a smashed TV. Whether they're good or not and wty??
                          • flocko
                            • Nov 2012
                            • 1121
                            • uk
                            #53
                            Yes i have seen them,do you have a parts list for this board as i am thinking that if i change IC733/Q818/Q603/and Q702 that should tick most of the known faulty components what do you think, as Q818( 2SK3018 ) is less than a £1 that with the other parts i could get out of this for under £10 Flocko
                            • tw2005
                              • Oct 2011
                              • 6458
                              Only list is what you'd have in the service manual, then a matter of either searching within the forum as i have listed some I have worked out or look at the markings and try google. Q603 is a real number as it is a panasonic product. the others will be found in the 5081 repair thread I did.
                              IC16773 TC7SH14F, Toshiba , Schmitt inverter ,marking HA
                              Q16701 MMBTA92 NXP (7E W)
                              Q16702 2PD601ART NXP (C3 W)
                              Q603 DSA2001S0L
                              If you get stuck by all means I'll see if I can ID it for you.
                              • flocko
                                • Nov 2012
                                • 1121
                                • uk
                                #55
                                Thanks for part numbers,have been looking for the TC7SH14F no one has this any were over here same with the DSA2001S0L, the others i can get for about £1 each over here or £1 per 100 from China,i will see if i can get some TC7S14F and the DSA2001S0L also from china i am in no rush to get the set running Flocko
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  TI have an exact replacement for the toshiba. RS UK have the other, Hope you can use 100 over time.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Sn74ahc1g14dbvr
                                    RS UK pack of 25
                                    • flocko
                                      • Nov 2012
                                      • 1121
                                      • uk
                                      #58
                                      Thanks TW i did not think to see if there was a sub on that,i can now get all now apart from DSA2001S0L over here. As for buying 100 i would put the rest on Ebay only need to sell one for a £1 to get my money back and could make £99.00 if i got lucky.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        These maybe correct size. You'll have to check. I got the wrong size and still managed to just solder it in.
                                        2N7002 is pretty common , original is 2SK3018T106 size is UMT3 or SOT323. Again up to you to be certain.
                                        http://uk.rs-online.com/web/c/semico...8&m=1&aaaExp=Y
                                        • flocko
                                          • Nov 2012
                                          • 1121
                                          • uk
                                          #60
                                          Thanks again TW, i have them all on order now i found some 2SK3018 the only missing part now is the panasonic DSA200iS0L for Q603 but will keep looking should be with me mid week,The IGBTs for the SS board i hope will also be here this week Flocko
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
