Transistor for Sylvania LC200sl8 LCD TV
  • geminidpr
    • Dec 2011
    • 41
    Can anyone tell me what transistor can I use to replace Q401? On the top it has a "K" and underneath C2026. I think it might be a KTC2026 but I'm not sure. Base to emitter and base to collector reads ok but It reads aprox 110 ohms between collector and emitter. I don't know if this is norm for this x-sistor. This x-sistor is used to power the inverter for the lamps. Any help will be appreciated. Thanx.
  • R_J
    • Jun 2012
    • 9624
    Re: Transistor for Sylvania LC200sl8 LCD TV
    There is a picture here of 2sc2026: http://www.ebay.com/itm/15pcs-2SC202...-/120953893556
    looks like what you describe
    • geminidpr
      • Dec 2011
      • 41
      Thanx RJ.....thats looks exactly like mine.
      • alpha1
        • Jul 2013
        • 5
        • Tanzania
        110ohms meter reading is not normal for that transistor,
        it is has a Short Circuit.
        It should read Over Range if measured out of circuit. According to its datasheet,it has the following parameters:
        Low saturation voltage Vce = Vcb = 60V
        Ic = 3A
        Veb = 7V
        Ib = 0.5A
        Transition freq = 30MHz
        You can get it off eBay as already pointed out by the other forum member.
        For equivalent,you can use 2SD1266 regardless of its small size,but it works.
        • geminidpr
          • Dec 2011
          • 41
          Thanx alpha....that clears my doubts as to whether it was good or bad.
          • vikivng
            guys..i need help with this lcd display used on ebikes pls.
            by vikivng
            This is an lcd display used on ebikes.
            long story short, there was condensation inside the unit.
            I opened it and thoroughly cleaned the pcb with isopryl.
            The board had no visible corosion.
            It powered on fine and was tested for an hour or so.
            However when connected to the bike,,it did not power on at all.
            I took it home and reopened it to take a look. There are no shorts based on MY testing.
            However,,when I probe the transistor and the mosfet gate in diode mode or contuinity mode, (one probe on transistor collector and one probe on mosfet gate}the unit...
            09-16-2025, 12:56 PM
          • SuperAman
            PNP transistor symbol?
            by SuperAman
            I have a question about PNP transistor symbol. Usually the emitter arrow pointing in the direction of the base is at top where the collector would be. I got asked on a test where the arrow is pointing toward the base but was in the spot of the collector. The answer choices was PNP or NPN and forward biased or reverse biased. So is it a PNP that is forward biased or reverse biased? Usually on the schematics for PNP the Emitter is on the top and collector is on the bottom....
            04-14-2025, 06:11 PM
          • esinior
            Smd code to part number
            by esinior
            Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
            I've attached pics of this part
            Thanks...
            08-20-2024, 02:50 AM
          • CoinCoin88
            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
            by CoinCoin88
            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
            09-15-2025, 03:36 AM
          • EasyGoing1
            Question about current balancing in LED strings
            by EasyGoing1
            I'm sure most of you are familiar with Paul Daniels ... who is someone I consider to be an expert in what he does. Not to mention he's an incredibly wonderful person and is always willing to help people find knowledge.
            He used this simple design to balance the current in some LED strings
            and I have a couple of questions about it if anyone can answer:
            1) What would determine the values of the emitter resistors?
            2) The fact that the collector of one transistor is connected to the base of all of them ... why would that not...
            09-24-2022, 10:35 PM
