Panasonic TX-P42S11B - 7 Blink Code
    Re: Panasonic TX-P42S11B - 7 Blink Code
    I've never encountered it myself before.
    • Fool2cool
      • Sep 2012
      • 17
      Excellent news, so my first repair is quite a rare fault haha!
      • tw2005
        • Oct 2011
        • 6458
        Originally posted by Fool2cool
        Haha should I take that as a compliment?
        Yeah its very strange that the line just stops, and you can actually see a physical mark with the panel turned off. The data connector on the C1 board I think it is on the far right where the vertical line is also gets very hot, I think if I understand correctly these have a chip on flex? and the large metal bracket is a heatsink?
        I've also re-seated the buffer connector a few times but it doesn't help.
        Thank you
        It's a compliment but I was half expecting panel damage so the picture you have is more than I expected, not in reference to your ability.
        Pity about the result but looks like all the boards are now confirmed ok
        • rmacintosh
          Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
          by rmacintosh
          I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
          The symptoms of the tv ar as follows:
          • Plug AC in to back of TV
          • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
          • The 3 blink code is given by the power LED
          • If the TV is unplugged and then
          03-14-2020, 12:24 AM
        • cloo
          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
          by cloo
          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
          After doing a factory reset this problem was gone and the picture was back to...
          01-06-2025, 06:02 AM
        • LongLiveMyPlasma
          Panasonic TC-P42ST30: Repair for 14 blink code
          by LongLiveMyPlasma
          My beloved Panasonic TC-P42ST30 has been stricken with the 14 blink code.
          I've spent many hours reading through forums, watching YouTube videos and reading the Panasonic plasma troubleshooting guide. But I'm a novice at this, and still need some help to cross the finish line.
          I understand the Panasonic troubleshooting guide suggests that the 14 blink code usually means there's a problem with either P-board or A-board. However, I also learned the problem frequently rests with the SN-board.
          Using my multi-meter, I was able to confirm the P-11 pin on the...
          05-18-2020, 10:48 AM
        • orbit417
          Panasonic Plasma tc-p55vt50 6 blink error code
          by orbit417
          Hi All,
          Thank you in advance for your advice.
          I have a Panasonic Plasma tc-p55vt50 that's about 9 years old and has just recently stopped working :-(
          I noticed that when I turn the tv on I hear a click then screen comes on for like half a second then shuts off and the led blinks 6 times.
          I did some googling and found several video's on trouble shooting all sorts of blink codes. I finally came across one that showed 6 blink error code but for a different model. It recommended disconnecting the SC board to determine if it was the A board or power...
          04-14-2021, 09:11 AM
          LCD LED TV Service Menu Codes
          ALL LCD LED TV SERVICE MENU CODES
          Service Menu Code with Board Name
          China Universal Board / Jumper Board Service Menu Code
          Changhong Ruba Service Menu Code
          Ecostar LED TV Service Menu Code
          Orient LED TV Service Menu Code
          Haier LED TV Service Menu Code
          TCL LED TV Service Menu Code
          Samsung LED TV Service Menu Code
          LG LED TV Service Menu Code
          Videocon LED TV Service Menu Code
          Supra LED TV Service Menu Code
          Toshiba LED TV Service Menu Code
          Symphony LED TV Service Menu Code
          Veste/ LED TV Service Menu Code...
          10-31-2024, 03:58 AM
